Author Topic: Starter relay went bad on my 71 Cuda?  (Read 2479 times)
Offline DocMel
« on: June 17, 2010 - 07:34:36 PM »
Im about wrapped up with my resto on my 71 Cuda, Auto Trans
I havent had any past probs with the starter, starter relay or the ignition switch.   Up until now that is................I went to crank it today, and have power to the stereo, etc, but I have absolutley nothing when I go to crank the engine.  No clicking, nothing.
I can jump the posts on the starter relay, and it cranks just fine
The starter relay looks very old, and Im thinking it just went bad?
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: Starter relay went bad on my 71 Cuda?
« Reply #1 on: June 17, 2010 - 08:31:08 PM »
check the neutral switch and make sure its plugged in securely
72rtchallenger
what happens in the garage
stays in the garage
Offline BIGSHCLUNK
« Reply #2 on: June 17, 2010 - 11:09:49 PM »
Auto trans...? Was anything moved or altered in relation to the colum & linkage. I went nuts for a day  only to find I had to readjust the rod....  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #3 on: June 18, 2010 - 05:04:35 AM »
Mine does the same thing sometimes when starting it from PARK.  All I do is slip the trans into Neutral and start it.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline BB73Challenger
« Reply #4 on: June 18, 2010 - 05:58:46 AM »
Had mine go bad on the Chally a few years back - had an event I was going to (of course) so as you said I jumped mine at the box for that day then after a 2 day wait got one from a store at home.
Jeff from Cleveland, Ohio
Offline DocMel
« Reply #5 on: June 18, 2010 - 06:04:56 AM »
Thanks Guys.   Ill get another today:  Easy $15 and it very old anyways.   Its an auto trans, shouldve said.   Ill double check the plug at the tranny, as well as the connector at the firewall just in case
Offline Katfish
  • 70 Challenger
« Reply #6 on: June 18, 2010 - 06:38:24 AM »
Easy why to check the neutral safety switch is with a DVM.  Just take off the connection at the fenderwell (near battery)and measure the resistance to ground when in park or neutral.  It should be a short, or near 0.
I had similiar problem as stated, replaced starter before figuring out my linkage needed adjustment.  It used to start in Neutral when Park wouldn't work, as stated above, then it just wouldn't start.
Offline ShelbyDogg
« Reply #7 on: June 18, 2010 - 10:20:26 AM »
Use a good test light to check the circuit before touching anything, so you'll know that you fixed the right side.
With the test light's ground wire hooked to the positive battery terminal, touch your probe to the small terminal (non yellow wire) on the starter relay. The light should be on when in park or neutral. (or clutch pushed in on a manual trans.
With your test light's ground wire hooked to the negative battery post, touch your probe to the small terminal with the yellow wire on it. The light should come when you hold the ign switch to the start position.  If not, then start at the Ign switch connector's yellow wire, then start following it through the bulkhead connector all the way back to that starter relay.
Using the test light is the most simple, quickest way to find the problem.
Offline DocMel
« Reply #8 on: June 23, 2010 - 01:19:39 PM »
Thnx for the help  It was the main harness connector at the firewall.  It had pulled slightly loose.
