Author Topic: Fast Idle Problems  (Read 1181 times)
Offline Pentastar Pete
Fast Idle Problems
« on: June 19, 2010 - 06:57:51 PM »
1970 340. I have a Demon 650 carb. Engine and carb about 5 years old.
Took the car out of winter storage and noticed that the idle sometimes would jump to 1500 rpm and stay there for a while then come down. All the linkages are fine.
Choke is set. Nothing hanging up. I also changed the carb gaskets. No vac. Leaks.
I also noticed that the left side headers are getting hotter then normal. All the plastic wire loom holders melted. I had then since day one and never had a problem.
The engine also sounds alittle different.
Could timing be an issue????  I'm at a loss...  :clueless:
Thanks
Pete
74 Rallye Challenger
73 Rallye Challenger
68 Charger RT
Re: Fast Idle Problems
« Reply #1 on: June 19, 2010 - 07:44:24 PM »
A timing problem would definitely cause the headers to be hotter than normal... I'm not sure about the rest. I know others have had trouble with Demon carbs.  Sorry I'm no help.    :sadwavey:
« Reply #2 on: June 19, 2010 - 08:00:31 PM »
How about a stretched timing chain?? or could I have jumped time??  would that cause an idle to raise like that?
68 Charger RT
Offline 72cudamaan
« Reply #3 on: June 19, 2010 - 11:50:25 PM »
Sounds to me like you have a idle circuit plugged, somehow causing the engine to run too lean. :2cents:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline BIGSHCLUNK
« Reply #4 on: June 19, 2010 - 11:52:20 PM »
I really doubt its a timing chain issue.....  :grinno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #5 on: June 20, 2010 - 10:43:45 AM »
Andy,   How would I check that idle circuit??  Someone else said that for some reason, it sounded like the carb leaned it self out.
68 Charger RT
Offline 72cudamaan
« Reply #6 on: June 20, 2010 - 12:14:44 PM »
I'm no carb expert by any means. But the fact that you are running super hot is definitely a condition of running lean. Maybe your float level is low. I guess I was looking towards  the idle circuit because only 1 side seems affected. Hopefully someone better with carbs can chime in and help. Also as a side note, could you have a sticky vac advance or sticky weights. I wonder if this might be causing an advanced timing condition that would raise nthe rpm's ?
« Reply #7 on: June 20, 2010 - 12:21:05 PM »
Andy,
Thanks very much for the time and input it puts me in the right direction..  :cheers:
68 Charger RT
