Author Topic: 833 4 speed grinding  (Read 1347 times)
Offline 4 speed fish
« on: June 20, 2010 - 11:44:54 AM »
Had the tranny rebuilt, then grinding going into 3rd and 4th.Took it back out  the guy said there were somethings he change.Replaced the tranny,still grinding in 3rd and 4th.Could it be the linkage?
Offline Cooter
    • christinecarclub.com
Re: 833 4 speed grinding
« Reply #1 on: June 20, 2010 - 12:09:52 PM »
Prolly not.......I'm thinking it's more than likely a blocker ring (BRASS RINGS) inside aren't stopping the gears in order to engage properly...That is of course, if the rebuilder didn't perform the old "Slick shift" and grind off every other tooth from the gear in order to bang shift it....
Offline swede-cuda
« Reply #2 on: June 20, 2010 - 05:11:16 PM »
 :wave:if both boxes grinds maybe you could try another gear box oil. :pullinghair:
Offline Cooter
« Reply #3 on: June 20, 2010 - 05:41:56 PM »
Either way, sounds like you need to find another rebuilder.....
Offline Changin Gears
« Reply #4 on: June 20, 2010 - 10:14:05 PM »
Not the linkage.  Sounds like the 3/4 synco assembly is assembed wrong.
