adjusting R/T hood
Author Topic: adjusting R/T hood  (Read 1886 times)
Offline dixiedog
adjusting R/T hood
« on: June 22, 2010 - 08:33:38 AM »
I read somewhere on here a long time ago about adjusting the hood on a challenger.  I have a 1970 with the R/T type hood.  It is giving me a problem.  When closing the hood the rear of the hood wants to stay up.  You have to go to the rear and pus each side down.  Any help would be most appreciated.  Thanks, Danny
Offline 73Chally
Re: adjusting R/T hood
« Reply #1 on: June 22, 2010 - 10:30:59 AM »
Most likely the rivets on your hinges are worn so the holes are oval.  I have the same problem, and am just waiting for the time to pull them out and send in for a rebuild, or buy a new rivet set (haven't decided yet).
Offline dixiedog
« Reply #2 on: June 22, 2010 - 11:36:10 AM »
No the rivets are fine.  I had this problem back in the day when I changed hoods on another one.  There was a thread on here awhile back on how to remedy the problem but I can't remember what it was.
Offline dutch
« Reply #3 on: June 22, 2010 - 11:42:42 AM »
loosen the front side hingebolts and push the hood all the way up. then have someone else tighten the bolts
*** Bart ***
Offline dixiedog
« Reply #4 on: June 22, 2010 - 12:28:32 PM »
I'll give that a shot Bart.  Thanks, Danny
« Reply #5 on: June 22, 2010 - 03:10:52 PM »
You need to raise the front of the hinge. Kind of the opposite of what you would think.
Offline 500Stroker
« Reply #6 on: June 22, 2010 - 06:33:01 PM »
From Resto Rick's site   Hood Hinge Installation/Adjustment
http://www.restorick.com/tech/topic.asp?TOPIC_ID=10
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #7 on: June 22, 2010 - 07:04:37 PM »
 :iagree: this worked for me and was perfect
72rtchallenger
what happens in the garage
stays in the garage
« Reply #8 on: June 23, 2010 - 02:18:20 AM »
It definatly is NOT the rivits , just over raise the front of the hood to twist up the front of the hinge & it will lower the rear of the hood when closed
Offline dixiedog
« Reply #9 on: June 28, 2010 - 10:38:43 AM »
It worked guys.  Thanks, Danny
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #10 on: June 28, 2010 - 05:20:20 PM »
So one could say if they had the opposite problem on one side that the front hinge bolt needs to go down ???
Go Fast & Have Fun...
« Reply #11 on: June 29, 2010 - 02:44:56 AM »
or raise the rear , Yes
