Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
need help with popping thru carb
« previous
next »
Print
Pages:
1
2
Author
Topic: need help with popping thru carb (Read 4264 times)
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Re: need help with popping thru carb
Reply #15 on:
June 28, 2010 - 06:10:35 AM »
Buddy of mine had a similar problem recently, engine would not rev high, that turned out to be a bad mechanical advance in the distributor. Worth checking before tearing down the engine.
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
djwhog
Jr. Member
Reply #16 on:
June 29, 2010 - 07:38:00 AM »
Yep that is possible too. Can you put a timing light with adjustable advance type gun and watch the timing to see what it does? Also you dont have vac advance do you?
Are the valve springs weak or maybe a broken one on the inak valve or valves?
Logged
dandsgcuda
Jr. Member
almost there
Reply #17 on:
July 02, 2010 - 06:44:21 PM »
an update the cam timing was off in the process of putting it back together.hard to see in a dimly lit garage.Thanks for all the advice.
Logged
djwhog
Jr. Member
Reply #18 on:
July 03, 2010 - 08:36:48 AM »
Nice, glad you got her fixed:) Should run better than ever...
Logged
dandsgcuda
Jr. Member
almost there
Reply #19 on:
July 05, 2010 - 01:14:04 AM »
well all is good know.Took the time this time and dreed the cam in got it to within 1 dgree of where it is suppose to be 106 manufacture 105 mine with 110 lobe center line puts it at 5 degrees advanced.Runs like a champ plulls real good up to 6500.Thanks for all your help.Now I can take on some hondas or new cameros.
Logged
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
