Author Topic: Correct Throw Out Bearing?  (Read 834 times)
Offline AMXguy
« on: June 22, 2010 - 07:39:10 PM »
SKF offers a standard and a self aligning throw out bearing assembly. which one is correct for a big block with an 833? I don't remember ever being asked which one I wanted.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: Correct Throw Out Bearing?
« Reply #1 on: June 22, 2010 - 10:02:47 PM »
One with the collar and one is just the bearing I think. Is one priced higher than the other?
« Reply #2 on: June 23, 2010 - 02:22:03 AM »
there are 2 , the 23 spline is smaller
the "big block" 18 spline is a larger brg & about 4 times the price
Offline AMXguy
« Reply #3 on: June 24, 2010 - 12:13:49 AM »
They both have the collar, and the specs say they're the same size. the only difference is one says self aligning, and cost twice as much. I don't know what self aligning means unless it's a type of bearing that can pivot on the race? we'd call original would not be self aligning I'd guess?
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline ntstlgl1970
  • T a c o c a t
« Reply #4 on: June 24, 2010 - 02:18:28 AM »
The self aligning is just a newer bearing technology, the thrust surface of the bearing can "self center". Either will work fine.
