Author Topic: Piston Pin weight 340  (Read 572 times)
Offline iNTP
« on: June 23, 2010 - 05:27:51 PM »
If anyone kind enough to let me know how much the 340 Piston Pin weight?
Or atleast can tell me how much the combination of "original 340 piston+ orignial 340 pin" weight? My book say 340 piston weights 719 grams, but they dont have Pin weight.
Thank you so very much!
Offline 71chally416
    • The Streetwalker
Re: Piston Pin weight 340
« Reply #1 on: June 23, 2010 - 05:40:19 PM »
984 diameter, 2.500 long, .150 wall, 125 gram weight (for Ross pistons...should be the same weight for stock 340 if pin is the same dimentions)
And I believe the piston weight includes the pin.  :grinyes:
Offline vinb
« Reply #2 on: June 23, 2010 - 10:19:17 PM »
If I remember right a 340 piston is 758 grams and the pin is 154 grams..
Offline ntstlgl1970
  • T a c o c a t
« Reply #3 on: June 24, 2010 - 02:09:53 AM »
I think the component weights "used to" be in the paper catalogs. On the Federal Mogul website, they have an electronic catalog listed under the training heading, maybe that info is still provided there.
Offline femtnmax
« Reply #4 on: June 27, 2010 - 11:05:06 PM »
The early 340 had different piston/pin weight than the later low compression 340, and even the "correct" year aftermarket piston may not have the OEM weight, not even close.  Be sure to match your weights correctly or the engine will have resonance vibration.  I would weigh the parts your taking out (piston and pin together) and match those weights, don't rely on a number in a book.
A lesson learned on my 340 duster from my mistake 30+ years ago.
« Last Edit: June 27, 2010 - 11:07:38 PM by femtnmax »
Phil
