Author Topic: Rear Anti-Sway Bar Opinion  (Read 991 times)
Offline RB2929
« on: June 24, 2010 - 07:28:39 PM »
Hi All-
I'm just looking/comparing different anti-sway bar options.
I like the Firm Feel rear anti-sway bar because it goes over the differential, like the original.
Cruising through eBay, I found this one.
It's from Addco (maybe through Summit?).  Price $143 +$12 shipping = $155.
Made of solid steel, 3/4 in, powder coated, with mounting HW
Link:
http://cgi.ebay.com/ebaymotors/Addco-Performance-Anti-Sway-Bar-Kit-236-/330444443179?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1971%7CModel%3ACuda&hash=item4cf0060e2b
- Sorry, uploader is full -- can't upload picture
Your thoughts?
Thanks,
Ron
Offline Challenger III
Re: Rear Anti-Sway Bar Opinion
« Reply #1 on: June 24, 2010 - 09:12:27 PM »
The link you have there does not fit challenger or barracuda.  :dunno:
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline djwhog
« Reply #2 on: June 24, 2010 - 09:36:45 PM »
get over the top luike a factory unit, better control and does what it is suppose to uch better. I think Firm Feel has them, they are more $$$s but worth it and look cleaner installed too!
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #3 on: June 24, 2010 - 09:54:19 PM »
addco makes a good bar, so does Helwig.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline 73Chally
« Reply #4 on: June 24, 2010 - 10:32:30 PM »
:iagree: I had a Helwig that mounted under the rearend, and dumped it after a month because it was junk.  It kept snapping the end link because it could not handle the stress, and their tech support was non existent other than to say yeah, that's a problem they've seen before.  Pay the extra money for the Firm Feel, or wait until you get a hold of an original.  You want one that mounts like the factory.
Offline autoxcuda
    • Spring Fling
« Reply #5 on: June 25, 2010 - 02:03:22 PM »
Hotchkis or Helwig rear bar with dog bone pivot endlinks. Not the old smashed doughnut style.
When you run those old style end links with poly bushings you have to have the alignment and angle set right. You may have to adjust the center spacer to the end link is totally paralell with the sway bar end link hole/arm and the frame or axle mount. This angle will change depending on what rear end ride height you are running.
The Hotchkis goes on the axle, but it's pretty light. You don't have to onbolt the rear end or drop the exhaust to get it in. It's adjustable too.
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
