I cant seam to get the new crate running at all, I changed the distributor to a msd unit to go along with the 6L box and blaster coil and rewired per instructions' mag pickup type" .
It would at least try to start before but now all I get is cranking and it pops once a rev or so.
Am i right when i set the oil pump gear straight down the center line of the engine then set the bug to point at #1?
It dose have the ballast for the ignition still attached and voltage regulator as well, are they need with the box?
The engine is a 10:1 compression and cam is a 296 duration cam,the ballancer is made by professional products could the timing marks be off?
I can get pics if need
Any help will be a godsend!
Thanks
