Author Topic: $ speed reverse light  (Read 1336 times)
Offline 4 speed fish
« on: June 26, 2010 - 11:18:04 AM »
Have my 833 4 speed rebuilt,got it back now the reverse light does not work. Any thoughts of what could of happened.
Offline Changin Gears
Re: $ speed reverse light
« Reply #1 on: June 26, 2010 - 11:33:57 AM »
Is the connector plugged into the switch on the trans?
« Reply #2 on: June 26, 2010 - 12:12:30 PM »
Yes
« Reply #3 on: June 26, 2010 - 12:17:05 PM »
You could unplug it and short the 2 connectors in the plug (paper clip would work), the liights should come on, if not its in the car.  if they do you can put the trans in reverse, and measure the resistance of the switch in the trans, it should be ~0 ohms.
« Reply #4 on: June 27, 2010 - 02:35:41 AM »
bad bulb ?
