Author Topic: Ballast Resistor Question  (Read 1481 times)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« on: June 27, 2010 - 09:47:02 PM »
Should my ballast resistor be getting HOT?  I mean it was so hot you could not touch the white ceramic part without it burning your finger.  This was only after a couple minutes of idling.  I don't remember it ever being hot like that before.  Is this a sign of needing a new one or is something else wrong?
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline Changin Gears
Re: Ballast Resistor Question
« Reply #1 on: June 27, 2010 - 09:54:04 PM »
That's normal, idle is when it gets the hottest.
Offline CudaNut
  • She's so fine ain't no tellin where the money went
    • CUDANUT.COM
« Reply #2 on: June 27, 2010 - 09:59:08 PM »
Yes, it will get hot. It's function is to "resist" current flow to control voltage to the coil, the excess current is dissipated in heat. From Wikipedia...
The term also refers to an automobile engine component that lowers the supply voltage to the ignition system after the engine has been started. Because cranking the engine causes a very heavy load on the battery, the system voltage can drop quite low during cranking. To allow the engine to start, the ignition system must be designed to operate on this lower voltage. But once cranking is completed, the normal operating voltage is regained; this voltage would overload the ignition system. To avoid this problem, a ballast resistor is inserted in series with the supply voltage feeding the ignition system. Occasionally, this ballast resistor will fail and the classic symptom of this failure is that the engine runs while being cranked (while the resistor is bypassed) but stalls immediately when cranking ceases (and the resistor is re-connected in the circuit).
"If I had my life to live over again, I'd be a plumber."
  Albert Einstein
Offline hooD
  • detroit iron
« Reply #3 on: July 01, 2010 - 04:57:22 AM »
Thanks, I feel better knowing that my ballast resistor is normal.
-Larry
1973 'CUDA 340
original owner
37,117 miles
