Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
4 speed identification
« previous
next »
Print
Pages: [
1
2
Author
Topic: 4 speed identification (Read 3250 times)
06Daytona
Sr. Member
on:
June 28, 2010 - 03:51:43 PM »
How do I figure out what transmission I have in my car? I can't really see the casting number on the side, but with a little cleaning I might be able to
Logged
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Changin Gears
Sr. Member
Re: 4 speed identification
Reply #1 on:
June 28, 2010 - 05:57:46 PM »
What is it your are trying to determine?
The '70 4 speed (common 23 spline) had 2.65:1 1st and the early syncro's. The 71-74 had the later syncro's and 2.47:1 1st. The 71-74 can be identified by looking for a rib on the side cover connecting bosses where the shifter arms attatch.
Logged
06Daytona
Sr. Member
Reply #2 on:
June 28, 2010 - 06:11:44 PM »
I'm trying to figure out what year the tranny is and anything else I can. The car started as an auto so I don't know anything about the 4 speed. If I need to replace anything on it I don't want to guess and buy the wrong parts. There are a few leaks on it around some of the seals so I'd like to replace them as soon as possible
Logged
Alaskan_TA
Guest
Reply #3 on:
June 29, 2010 - 12:47:53 AM »
Does it have a VIN pad on the passenger side?
If it does, what are the numbers on it?
If no pad, then it would be from sometime in 1968 or earlier.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
June 29, 2010 - 02:55:20 AM »
you could post a picture of it , it is doubtful it would be pre 70 as the tailshaft didn`t have a mount pad for the shifter to mount in the correct location
Logged
06Daytona
Sr. Member
Reply #5 on:
June 29, 2010 - 08:39:00 AM »
Here's 3 pics I got of it. The car is on the ground so I had to crawl under. They aren't very good pics, but they might help.
On a side note, what is this thing? It's On the rad support behind the left headlight.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #6 on:
June 29, 2010 - 12:52:25 PM »
it looks like a correct trans for the year , it seems to have the cast side cover & the older style of reverse detent
Logged
06Daytona
Sr. Member
Reply #7 on:
June 29, 2010 - 01:01:24 PM »
Thanks. Somebody changed a bunch of bits on the car so I'm not sure what stuff is from what year
Logged
ShelbyDogg
Sr. Resident
Reply #8 on:
June 29, 2010 - 02:06:48 PM »
can you take a side picture of that "thing"
Logged
06Daytona
Sr. Member
Reply #9 on:
June 29, 2010 - 02:29:58 PM »
Side view
Down the back side by the fender
Logged
ShelbyDogg
Sr. Resident
Reply #10 on:
June 29, 2010 - 03:14:34 PM »
Could be a compressor for some kind of horn?
Could be an electric siren for an alarm system?
What does it do when you "hook it up"?
Logged
06Daytona
Sr. Member
Reply #11 on:
June 29, 2010 - 03:23:34 PM »
I haven't tried to hook it up yet. I thought it might be factory because there's a bracket behind it that it's attached to. I'm a little spooked with the idea of hooking it up before I know what it's supposed to be.
That's what the top looks like after I scraped off some of the flat black that it was hosed with. There are 2 terminals and 3 things that look kind of like hose hook ups along with a thing with a cap on it. There's a wire coming off the bottom part that goes to the positive on the relay? on the drivers inner fender and I'm guessing it's a negative that's taped off and just sitting there.
Last Edit: June 29, 2010 - 03:51:09 PM by 06Daytona
Logged
06Daytona
Sr. Member
Reply #12 on:
July 08, 2010 - 12:20:17 PM »
Quick question here. I want to check my trans fluid and don't know where the fluid fill is on it. Is it in any of the pics I posted so I can check it before the weekend?
Logged
Changin Gears
Sr. Member
Reply #13 on:
July 08, 2010 - 01:33:56 PM »
It's on the passenger side, about 1/2 way up, on the main case (pipe plug).
Logged
06Daytona
Sr. Member
Reply #14 on:
July 08, 2010 - 02:03:45 PM »
Cool. Thanks
Logged
Print
Pages: [
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
