Author Topic: No front lights  (Read 2907 times)
Offline 06Daytona
No front lights
« on: June 28, 2010 - 08:02:40 PM »
I got the starting problem fixed I think(knock on wood) but now I have no headlights or front signals. I have tail lights and my rear markers and break lights. I tried my hazards and my tail lights flash fast, but not my side markers. There's a chance that I accidentally disconnected something under the dash when I was playing under there but I have so many random spare wires under there that I wouldn't know what color to look for. The dash lights work, but the dimmer has old man syndrome and goes bright and dim as I turn it up. I can't do anything tonight, but I'm going to attack it tomorrow.
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline ShelbyDogg
Re: No front lights
« Reply #1 on: June 29, 2010 - 12:44:01 AM »
Start with the middle firewall plug. Looking from the engine side.
First make sure that your ground wire from the headlights and parking lights  is grounded well. It hooks under a bolt on the radiator support right next to the battery. A small ground wire right from the negative battery clamp should go to the same screw.
LEFT SIDE TOP                      RIGHT SIDE TOP
Starter-yellow                       Left turn
Park lites BLK-Y*                   High Beams
Rt Turn TAN                          low beams
Brake prop valve                   12V  RED From Fuse Link
Re: No front lights
« Reply #2 on: June 29, 2010 - 02:43:14 AM »
side markers do not flash they are just a park light
Offline 06Daytona
Re: No front lights
« Reply #3 on: June 29, 2010 - 08:23:10 AM »
I wiggled the headlight relay and the lights started working again. I''ll spend a few hours cleaning up the connections and maybe replace the relay while I'm at it.
Offline ShelbyDogg
Re: No front lights
« Reply #4 on: June 29, 2010 - 10:15:40 AM »
You didn't tell us that you had put in a relay.   Make sure that it isn't mounted upside down!
Offline 06Daytona
Re: No front lights
« Reply #5 on: June 29, 2010 - 11:39:38 AM »
Maybe it's not a relay. I meant the little box on the rad support that has a bunch of wires plugged into it.
Offline ShelbyDogg
Re: No front lights
« Reply #6 on: June 29, 2010 - 12:00:41 PM »
:clueless:
Good luck with that one.............
Offline 06Daytona
Re: No front lights
« Reply #7 on: June 29, 2010 - 12:54:51 PM »
This is the thing I'm talking about
It's working fine now. I tightened the screw holding it in and checked all the connections
