Author Topic: 1st time clutch installation  (Read 749 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
« on: June 28, 2010 - 09:57:30 PM »
I am going to tackle a clutch for the 1st time. I have a brand new flywheel, clutch disk, pressure plate, throw out bearing and pilot bearing. I know the pilot bearing goes into the back of the crank. Then the flywheel, then clutch disk with alignment tool and then the pressure plate. I get a little fuzzy after that. I have a challenger with a 360 and e body 4 speed. I saw a video of a "chevy" clutch installation where they put everything (flywheel disk etc.) on and then bolted the bell housing to the block and then mated up the 4 speed. My ebody 4 speed has the threads in the transmission. So I wouldn't be able to start the bolts that attach the bell housing to the tranny because they start from the inside. Does the bell housing attach to 4 speed 1st before attaching it to the block?  if so, how would I install the throw out bearing?
« Last Edit: June 28, 2010 - 10:02:33 PM by Scat Pack Fever »
Offline 73EStroker
Re: 1st time clutch installation
« Reply #1 on: June 28, 2010 - 10:57:42 PM »
Not sure why your bolt threads are in the tranny. Mine are in the bellhousing and the 4 bolts enter from outside and inserted forward into the bellhousing. You should be able to install the bell first. Bit of a pain getting the throwout bearing all sorted out as the tranny goes through the bell housing hole but I have a tranny jack and a 4 post hoist. But like I said, it is doable the way you described it.
Good luck
Barry (Salmon Arm)
Offline Aussie Challenger
« Reply #2 on: June 29, 2010 - 09:38:13 AM »
The Chevy install is basically the same as the MOPAR, the only trans that has the bolts inside the bellhousing are the autos, all the manuals I have seen have the bolts on the outside.   :working:
Don't forget to lube the spigot bush if you are using a bush.   :2thumbs:
« Reply #3 on: June 29, 2010 - 06:59:40 PM »
O.K. everyone! I think it is time for me to go on a vacation. Either that or someone took my tranny and replaced it with the correct one. I looked at the tranny last night and the threads are in the bell housing and not the 4speed. I could have sworn that the threads were on the 4 speed, but oh well. Maybe I need glasses :dunno:
