Author Topic: Rallye Tach Wiring  (Read 726 times)
Offline Cudaah
Rallye Tach Wiring
« on: June 29, 2010 - 09:04:25 AM »
I tried finding some info on hooking up the tach on my rallye dash but found very little.  I know one wire goes to the - negative coil but what about the other connector?  Does that just go to a power source?
Thanks
Offline ShelbyDogg
Re: Rallye Tach Wiring
« Reply #1 on: June 29, 2010 - 10:11:53 AM »
Yes.  Should be a blue wire that goes over the terminal like the other gauges. If you don't have one, tap into the wire supplying the voltage limiter.
Offline Cudaah
« Reply #2 on: June 29, 2010 - 04:06:33 PM »
thank you
