Author Topic: Rear End with no Snubber?  (Read 2960 times)
Offline dutch
Re: Rear End with no Snubber?
« Reply #15 on: June 29, 2010 - 06:43:42 PM »
anyone got some pics of an e-body with dana and snubber on the car?  I`ve got the dana and the e-body ,but no snubber... tnx
*** Bart ***
« Reply #16 on: June 29, 2010 - 06:59:07 PM »
Here are some. would like to see more added to it. hint hint.
http://www.cuda-challenger.com/cc/index.php?topic=67180.0
Offline Mopar_Mudder
  • I'm a llama!
« Reply #17 on: June 30, 2010 - 09:15:59 AM »
The stands for the stock snubber weld right on the rear end in the original area like the car snubbers do.  They are round bar stock, (3)cut on the correct angle to fit the center section, then drilled and tapped to fit the correct size snubber bolts. Once mounted, it all looks just like the original car dana set up and works just like it to.  It is a very simple procedure to do. Takes about an hr or less once on jack stands. Super Chryco could do it in 10 minutes
Don't know if I like the idea of welding to the case, is thier any pictures of this weld on mount?
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
« Reply #18 on: June 30, 2010 - 11:21:35 AM »
Never been able to get anything welded to cast iron , I know you need a lot of heat &  a high nickle rod to make it work
« Reply #19 on: June 30, 2010 - 03:15:42 PM »
The dana center isnt cast iron.  It's a simple mig weld job, nough said, it welds right on, and it holds. Look up doc diff and call him. I dont have a pic. I bought the kit, welded it on and it is working good with no issues, I have put it to use a bunch of times now
