Author Topic: 5/16'' x 24 Heli Coil - Need to borrow one ...... OR........  (Read 3536 times)
Offline Glennster
« on: July 01, 2010 - 04:19:03 PM »
 If any body has a 5/16'' x 24 Heli Coil they could loan me I'd sure appreciate it.  Or, I can buy the actual coils cheap, what I cant figure out is the size to drill and the correct tap to use...... I stripped the stud hole on my new radiator fan clutch....BUMMER!
Any ideas????
THANKS!!!
Offline cudazappa
Re: 5/16'' x 24 Heli Coil - Need to borrow one ...... OR........
« Reply #1 on: July 01, 2010 - 04:30:36 PM »
5/16-24 helicoil uses a 21/64" drill.
You need to use the special heli-coil tap.  McMaster.com #91709A153
you know about the coils...  Then there's the tool, which I don't have for that size... sorry.
2015 Dart GT - Daily Driver
Offline GoodysGotaCuda
« Reply #2 on: July 01, 2010 - 04:58:41 PM »
have you considered a thread chaser? they are designed to help clean up existing threads.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Glennster
« Reply #3 on: July 01, 2010 - 06:18:04 PM »
There's not much in the way of threads to chase. I ran the stud in a bit crooked, then when I tightened it, it pulled straight and ripped the threads out. That seems like soft aluminum.....
  I think I could get the coil in with a home made tool, the tough part is the correct tap size....
Offline 422STROKER
  • Member Since 6/3/06
« Reply #4 on: July 01, 2010 - 09:52:35 PM »
Would the insert throw off the balance?  Maybe a new fan clutch is safer?
 :dunno:
Tom
Tom
Offline Glennster
« Reply #5 on: July 01, 2010 - 10:35:20 PM »
 Is balance an issue there?
Offline 422STROKER
« Reply #6 on: July 02, 2010 - 05:41:48 AM »
I don't know, but anything rotational out of balance may cause problems I'd think.  Maybe not cause a problem with the motor itself but the water pump?  May be fine too though.  Just throwing it out there though.
Tom
Tom
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #7 on: July 02, 2010 - 07:27:20 AM »
 :dunno: Please excuse my general ignorance here, but is it possible to just tap it to the next size, then merely changing bolt size?
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline Glennster
« Reply #8 on: July 02, 2010 - 11:07:47 AM »
 If I go to the next size up, them I have to drill the fan to a larger hole size. Not a big deal, but I'd prefer to stick with the same size threads....
« Reply #9 on: July 02, 2010 - 12:29:19 PM »
I think i have a spare kit I could mail out , or you could just buy a kit for $20 or so which about what the shipping would cost there & back
Offline Glennster
« Reply #10 on: July 02, 2010 - 01:08:40 PM »
 THANKS for the help and the offers...... The tap I need is a 10M X 1.0, I've got a buddy that has one!  The cheapest one I could find around here was $38. I bought the coils for $10, I can borrow the rest of the stuff.
« Reply #11 on: July 03, 2010 - 12:54:12 AM »
Harbor freight man! you can get a metric tap set for super cheap. It'll do that job. I wouldn't go trying to tap stainless steel or cast with it. Little stuff like that, it's done me well..
1976 Dodge Warlock
Offline 422STROKER
« Reply #12 on: July 03, 2010 - 05:59:20 AM »
All that work and there are fan clutches at the parts store for 30 bucks.LOL
Tom :drunk:
Tom
Offline Glennster
« Reply #13 on: July 03, 2010 - 08:17:08 PM »
 I went to O'Reillys, they had the standard for $30 and the HD version for $50.  When I used the HD, I had water temps that were 15 degrees less, that's why I fixed the one I had. But I had to build a collar for the DH, the hole for it was .750'', the hole on the standard was .625''.
Offline 422STROKER
« Reply #14 on: July 03, 2010 - 08:28:26 PM »
I hear you, just bustin 'em a little!LOL
I need a HD on mine, That has the silicone in it right?  I have a small spring on mine and wonder sometimes if it's working properly.
Tom :2thumbs:
Tom
