the system is designed to work that way , if you lost fluid in one system fornt or rear the other should still have pressure with a lower pedal
thats what i thought also,,,backed off the parking brake today and turned the adjusters almost a full turn.cant test it with the engine running until tomorrow,changed the intake gasket today because of a very slight vacuum leak.guess i should have read the directions from edelbrock when installing there repro 6-pack intake that required the paper gaskets...the only variable here is the rod coming out of the booster,,i did not adjust it when i installed the master..theres play in the pedal so i hope that says something positive..oh well,,if i have to take the master off to set it at least i have these speed bleeders,,i love them...will know tomorrow.thanks tony
