Author Topic: Steering Column - Lock Cylinder  (Read 2149 times)
Offline CUDA JAS
  • vroooooom!
« on: July 03, 2010 - 07:32:34 AM »
Well my car left me stranded last night...the key would not go into the ignition. :stomp: :swear: :stomp: :swear:  My guess is the lock cylinder is fubared. Glad I have a spare column! :bananasmi  I have a couple of questions:
1. how difficult is it to change the lock cylinder (74 cuda)?
2. can the lock cylinder be changed without changing the ignition switch?
3. do you have to remove the steering shaft from the column to remove the lock cylinder (as per the FSM)?
Thanks,
Jason
« Last Edit: July 03, 2010 - 07:40:16 AM by CUDA JAS »
74 'cuda 360/727
Just call me a gearhead!
wagesofsin
Re: Steering Column - Lock Cylinder
« Reply #1 on: July 03, 2010 - 09:15:32 AM »
1) gravy
2) yes
3) no
Offline cj
« Reply #2 on: July 03, 2010 - 01:13:43 PM »
I just did the 73 Challenger, if I can do it anyone can.
There were a couple times I had a hard time figuring out how to get the next piece off.  The hardest part for me was getting that stupid o-ring off.  Then there's a steel band at the base of the interlock that has to slide off and a pin knocked out underneath.  That pin is a little wider at one end and will only knock out one way.
I got the ignition lock cylinder with matching door locks & 4 keys (2 cut, 2 uncut)  for $55 from a guy on ebay from Thunder Bay.
I'll be doing the Barracuda this winter cause the steering column was changed on it and the door locks and ignition don't match.  It's a PITA carrying that extra key and trying to figure out which one is for the door and which one starts the car.
This thread has some info
http://www.cuda-challenger.com/cc/index.php?topic=37458.0
Cheryl
"Mopar or No Car"
1973 Challenger
1974 Barracuda
2006 Charger Daytona Torred
Offline 422STROKER
  • Member Since 6/3/06
« Reply #3 on: July 03, 2010 - 08:36:23 PM »
I remember doing mine and the last part was a pita but I was able to get it without any special tools.
Tom
Tom
Offline CUDA JAS
  • vroooooom!
« Reply #4 on: July 03, 2010 - 10:07:11 PM »
Hey thanks guys..got it done..,.took a little longer than I hoped, but was not too bad.  I spent more time going out to get the right length bolts for the steering wheel puller and new snap ring pliers (bought two and took one back (wrong size).
Got the car started and moved out of the drive way, :clapping: only to find a fuel leak!!!  :banghead:
Oh well, I can fix that!!!
Jas....still :working:
74 'cuda 360/727
