Maybe valve clapping at 12-1500 Rpm
Author Topic: Maybe valve clapping at 12-1500 Rpm  (Read 1015 times)
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« on: July 04, 2010 - 02:47:13 AM »
Hi Guys  :wave:
I have a clapping noise at 12-1500 rpm on my ´70 318. It souns like valvetrain noise.
I have new lifteres and exhaust gaskets. checket all the bolts in the valvetrain.
My engine timing says, at idle 15 degrees and 34 degrees at 3000 rpm with out vacuum, fine i think. But with vacuum it advance up to 55 degrees could that high advance be the reason for the clapping?
Thanks Guys
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
Offline UKcuda
  • Tell them I'm on my way
Re: Maybe valve clapping at 12-1500 Rpm
« Reply #1 on: July 04, 2010 - 03:16:51 AM »
.............could that high advance be the reason for the clapping?
Don't think so but there's an easy way to find out.
'72 'cuda
Offline Danishmopar
« Reply #2 on: July 04, 2010 - 03:52:01 AM »
Hi.
Its still there when i unhock the vacuum. But after I have realy have fine adjustet the timing it sems to be better.
 :cheers:
Offline Aracer
« Reply #3 on: July 07, 2010 - 12:35:40 PM »
Tighten the spring inside the vac. pot, counter clockwise to make it less sensitive with an Allen wrench.
Offline Danishmopar
« Reply #4 on: July 08, 2010 - 04:25:01 PM »
Hi Guys.
Thanks for the advice. She running super now.
 :cheers:
