1970 Challenger and 440-6 engine
Author Topic: 1970 Challenger and 440-6 engine  (Read 2387 times)
Offline pistolgripripper
« on: October 22, 2004 - 04:59:42 PM »
1970 Challenger, runs and drives. Original 318 car, has a small block in it now with headers, aluminum intake, and 4 barrell carb. Not sure of engine size (tips on telling size?). Missing some exterior trim, and rear valance. Needs interior work. Has new headliner and vinyl top. Seems solid except trunk floor. $7000. Will include 440-6 engine for $2000 more.
[attachment deleted by admin]
Offline Carlwalski
Re: 1970 Challenger and 440-6 engine
« Reply #1 on: October 22, 2004 - 06:09:55 PM »
Is that a 1970 Block? Would you sell the engine alone?  ??? :D
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Plum6Pak
« Reply #2 on: October 22, 2004 - 07:51:57 PM »
Hey PG, lets see some numbers off of the engine, it looks like a RB to me, if it's an HP it's worth every penny of 2000.00 if it isn't trashed inside and worth close to that anyway!  Check the engine ID pad right behind the water pump up close to the valley pan. :D
Offline B571RT
« Reply #3 on: October 24, 2004 - 07:07:48 PM »
Man I wish I had  9,000. That is one of the best deals I've seen in awhile.  :-[
chargin
« Reply #4 on: October 24, 2004 - 07:08:31 PM »
where is the car located? and is it drivable?
« Reply #5 on: October 24, 2004 - 08:42:42 PM »
The car is in northwest Indiana. Yes, it runs and drives. I will try and look at the 440 block to see what the numbers say.
« Reply #6 on: October 27, 2004 - 05:49:32 AM »
The 440 has a casting date in '69, but the pad says G440   12 16HP. That's all the numbers I can see. Also, the heads on the engine are supposed to be '67 smaller chamber HP heads. They have HP on them. Just a little FYI...
Offline Bart
« Reply #7 on: October 27, 2004 - 08:48:38 AM »
Pistolgripripper,
Want a Harley for that Challenger?
Bart
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
Plum6Pak
« Reply #8 on: October 27, 2004 - 02:34:16 PM »
 :o Wow PG, those numbers indicate that could be the engine that belongs in the car, build date of Dec 16th 69 would be right for the 70, maybe the original 6Pak setup as well. What does the harmonic balancer look like? Check out the picture and it should have a cast crank looking dampner on it, the crank for a 6Pak engine is forged steel but with the added weight of the 6Pak rods, they added the external balance on the 6Pak engines.  :)
« Reply #9 on: November 05, 2004 - 06:28:51 PM »
Price has been lowered to $5800 on the car. MUST sell!
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #10 on: November 06, 2004 - 01:03:08 AM »
For the car and the engine???
Member Since January 14, 2002
« Reply #11 on: November 06, 2004 - 05:44:51 AM »
Price is for the car only...Thanks. I can't believe I can't sell this car with the current prices out there. ???
  • Pearl Harbor, HI
    • C-C.com
« Reply #12 on: November 06, 2004 - 10:13:05 AM »
Me either I was very shocked that someone didnt jump all over this one already.
Cuda Guy
Plum6Pak
« Reply #13 on: November 06, 2004 - 11:03:53 AM »
 cry I would have jumped all over it if I didn't have so much into the Chally already. I do take charity though!!  grinyes Easiet way to donate to the Cuda fund is just to put it into my PayPal account, anyone???
