Author Topic: 71 chally Brake lights/Stop lights not working  (Read 2110 times)
Offline thenuke1
« on: July 04, 2010 - 10:42:14 PM »
turn signals work
emeregancy lights work
front lights work
pretty much everything else works except the dame brake lights ...
i already checked the fuse and its not that. We checked the brake switch and thats not it.
I saw that it might be the Turn Signal Switch ? but how could it be that ? and where is it located?
HELP ? please
« Last Edit: July 04, 2010 - 10:53:02 PM by thenuke1 »
(OO{+++++++}I{+++DODGE}OO)
     o                               o
71 Challenger
If its got BOOBS or an ENGINE, your gonna have problems.
Re: 71 chally Brake lights/Stop lights not working
« Reply #1 on: July 04, 2010 - 10:56:59 PM »
I assume you are getting power in & out of the brake switch ,from there it goes up the column to the turn signal switch under the steering wheel from there it goes out the the brake lights .
Offline wally426ci
    • maryland mopars
« Reply #2 on: July 05, 2010 - 09:00:55 AM »
Maybe a bulb socket fell out of the housing, sometimes when you put stuff in the trunk, a socket will fall out of the light housing.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline thenuke1
« Reply #3 on: July 05, 2010 - 09:57:52 AM »
nope that was another place that we looked at first
its probably the TS switch ... the only was for us to test it without removing the steering wheel is to connect it outside near the brake
     o                               o
71 Challenger
Offline thenuke1
« Reply #4 on: July 06, 2010 - 09:14:51 PM »
we checked the all the wires and we r getting power from the brake switch so could the last resort be the TS Switch ?
so could someone point me in the right direction? which wires pertain to the brake lights
is the turn signal switch just that yellow portion ??? or is it the entire part ??
if so how would i go about removing the old yellow one and putting in the new one ?
my dad refuses to believe that the  turn signal switch has anything to do with the brake lights. So much so that he has removed the brake light switch. we found out it does work
« Last Edit: July 06, 2010 - 11:08:24 PM by thenuke1 »
     o                               o
71 Challenger
Offline thenuke1
« Reply #5 on: July 07, 2010 - 09:55:51 PM »
ok so instead of just getting a TS switch the car is going to the shop ...
can anyone tell me if it IS the TS suitch would it be the entire part or just thethe yellow piece
     o                               o
71 Challenger
« Reply #6 on: July 09, 2010 - 01:57:03 AM »
Not sure which part is yellow but it is the entire part tht the wiring is attached to
Offline Strawdawg
    • Vortex Buicks
« Reply #7 on: July 09, 2010 - 10:39:08 AM »
the wiring diagram shows the circuit running thru the TS
Offline thenuke1
« Reply #8 on: July 14, 2010 - 03:11:19 PM »
thanks guys it ended up being the mother$%$^@#^$#^ TS Switch ... lol
     o                               o
71 Challenger
« Reply #9 on: July 14, 2010 - 11:00:04 PM »
do you need me to get you one ?
Offline ShelbyDogg
« Reply #10 on: July 15, 2010 - 12:35:28 AM »
So now you can tell him that you know more than he does!
Offline thenuke1
« Reply #11 on: July 15, 2010 - 06:03:21 AM »
we were able to get one for 40 bucks thanks CP !
     o                               o
71 Challenger
« Reply #12 on: July 16, 2010 - 03:19:54 AM »
Cool  :2thumbs:
