Author Topic: Front disc brake upgrade for a '73 cuda ?  (Read 3185 times)
Offline vpittman
« on: July 06, 2010 - 07:42:19 PM »
Hi all,
I'm looking to upgrade the front disc brakes on my '73 cuda with 11.75" rotors and lightweight calipers... I really like the sbbc brake kits but they only fit drum spindles, and wilwood is too small
Where can I find something to fit ?
Thanks
Victor
Offline Katfish
  • 70 Challenger
Re: Front disc brake upgrade for a '73 cuda ?
« Reply #1 on: July 06, 2010 - 07:44:53 PM »
Factory set-up is pretty good option if you already have the disc spindles.
http://www.moparaction.com/tech/archive/disc-main.html
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #2 on: July 06, 2010 - 08:23:47 PM »
factory style disc cinversion kit, 850.00
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #3 on: July 06, 2010 - 08:49:40 PM »
Wilwood is too small as in the 10.5" rotor diameter or the caliper size? I've got a kit to adapt Wilwood calipers to the factory 11.75 rotors.
Offline vpittman
« Reply #4 on: July 06, 2010 - 10:26:00 PM »
HP2,
Wilwood rotors are too small... Is the kit complete with rotors and calipers or just a bracket ?
« Reply #5 on: July 07, 2010 - 09:10:46 PM »
All I have is the bracket kit. You would need to source your own rotors, bearings, calipers, and hoses. But, I'll cut you a better deal on it than you can find anywhere else, $150. Add calipers and pads $400, and rotors and bearings for $150 and you have major stopping power with a choice of pad compounds.
BTW, Wilwood does offer a 12.12" kit. This is the biggest you can fit in to some 15" wheels. But they are a bit more expensive than their 10.5" kits.
« Last Edit: July 07, 2010 - 09:13:05 PM by HP2 »
