Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Exhaust Systems
(Moderator:
Chryco Psycho
Exhaust manifold ?
« previous
next »
Print
Pages: [
1
Author
Topic: Exhaust manifold ? (Read 1453 times)
mach3107
Jr. Member
Exhaust manifold ?
on:
July 07, 2010 - 12:07:37 AM »
my 440 has a leak in the exhaust manifold gasket (standard felpro gaskets) at cylinder 8 towards the stud. They are stock manifolds. Is it a good idea to try thicker gaskets? A friend recommended a really thick one made by Mr. Gasket.
Logged
72cudamaan
Resident
Re: Exhaust manifold ?
Reply #1 on:
July 07, 2010 - 08:33:01 AM »
The manifold is probably warped, so the best choice is to remove it, check flatness with a straight edge and if warped have it resurfaced or milled flat.
Logged
If I cant fix it, it's broke
Andy (phukker whither)
ireland383
Jr. Member
Reply #2 on:
July 07, 2010 - 03:12:11 PM »
I never ran gaskets with mani's.
Logged
1971 Plymouth Barracuda
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
July 09, 2010 - 02:27:00 AM »
Exactly , I use a thin layer of high heat silicone only when using manifolds , using a gasket just causes leaks
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Exhaust Systems
(Moderator:
Chryco Psycho
Exhaust manifold ?
