Author Topic: Help 74 cuda front anti swaybar pic or diagram  (Read 766 times)
Offline Talkwrench
  • Perth, Western Australia
« on: July 07, 2010 - 12:24:02 AM »
Help can someone show me a  pic or diagram of a 74 cuda front anti swaybar setup. Mine doesn't have one  :o  Where to get one..:clueless:
"Came too close to dying to stop living now!"
Offline Strawdawg
    • Vortex Buicks
Re: Help 74 cuda front anti swaybar pic or diagram
« Reply #1 on: July 08, 2010 - 11:07:15 PM »
there is a drawing on here somewhere showing the brackets....saw it the other day, but, I don't recall which post it was in.  Or, you could buy a set of bolt on brackets from Firm Feel or weld on brackets from Hotchkis.....may be others as well, but those two come to mind
« Reply #2 on: July 09, 2010 - 02:47:40 PM »
The sway bar setup is the same between Cuda's and Challengers.  All years are the same as well.  Any undercar shot of an E-body will show you what you need to know.  Like what was said above...your control arms are missing the sway bar brackets.  You can buy the brackets and have them welded onto your origonal lower control arms.  Then all you'd need is a used factory bar, and the bushings.  It's a very simple setup.
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: July 09, 2010 - 09:41:34 PM »
