Author Topic: Header bolts leak coolant  (Read 2288 times)
Offline boxfox
« on: July 07, 2010 - 08:35:43 AM »
How normal is it for the header bolts to leak coolant out of them?
Because mine do if I tighten them, and I've got one bolt that doesn't seem to be seating properly and it drips.
Re: Header bolts leak coolant
« Reply #1 on: July 07, 2010 - 08:39:38 AM »
Put some liquid Teflon sealer on the threads and reinstall. The exhaust bolts go into the water jacket on both small and big block.
Offline GoodysGotaCuda
« Reply #2 on: July 07, 2010 - 10:41:03 AM »
Yep, I use high temp ultra copper rtv on those bolts, never had a leak
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 71chmark
« Reply #3 on: July 07, 2010 - 11:16:10 AM »
teflon tape here. no leaks.
I may be schizophrenic,
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #4 on: July 07, 2010 - 11:24:23 AM »
Ultra Copper RTV works great for sealing the water jackets and works great for header gaskets sealing.
1996 Dodge Viper GTS Coupe
« Reply #5 on: July 07, 2010 - 12:28:14 PM »
Does this apply to aftermarket Aluminum heads (Edelbrock) as well or just the cast iron heads?
« Reply #6 on: July 07, 2010 - 01:52:08 PM »
Humm don't know? But it wouldn't hurt anything using sealer on them anyhow .
« Reply #7 on: July 07, 2010 - 04:02:31 PM »
A tube isn't all that expensive, and it will give you some insurance if in case you are going into the water jackets. All you need to do is rub the sealant on the first couple of rows of threads...Then as you screw the bolts in, it will spread out over the other threads.
Offline boxfox
« Reply #8 on: July 07, 2010 - 08:14:41 PM »
Alright I shall do that, thank you gentlemen
« Reply #9 on: July 09, 2010 - 02:29:01 AM »
Alum heads have blind holes & do not go into the water jacket
