Author Topic: Spinning inner tierod end  (Read 705 times)
Offline arcticmopar
  • Yukon Canada
« on: July 07, 2010 - 01:05:22 PM »
Cant seem to win for loosing. :swear: Was one nut away from putting the chally back together from having the oil pan off and the drivers inner tie rod wont tighten. I think the ball is just spinning inside, the threads look fine. Now I cant get it tight enough or get the nut off. :pullinghair:
 Anyone else run into this and know how to get it off short of a torch. :bigsmile:  and if nothing else thanks for letting me rant and vent.
RUNS WHITH SISSORS!  and  DIGITALY CHALLENGED!
Re: Spinning inner tierod end
« Reply #1 on: July 07, 2010 - 01:37:46 PM »
Try squeezing the tie rod down against the steering knuckle.  That might put enough friction on the ball so you can take the nut off.  That happens a lot.
« Reply #2 on: July 07, 2010 - 01:56:18 PM »
I have used a jack and a piece of wood to put some pressure on the tie rod into the taper to keep it from spinning?
Offline arcticmopar
  • Yukon Canada
« Reply #3 on: July 07, 2010 - 02:12:59 PM »
 Thanks guys going to try that tonight.
Offline Aussie Challenger
« Reply #4 on: July 08, 2010 - 06:46:51 AM »
That can happen especially if the taper on the tie rod or the tapered hole are not totally clean. brads70 is what I have done in a couple of extreme cases.   :2thumbs:
