Author Topic: cuda hood question. need quck answer  (Read 850 times)
Offline GreenFish
« on: July 09, 2010 - 02:36:05 PM »
Looking at a hood at carlisle. Its a rally hood says 71-74. Are the 70,s the same hoods?
Re: cuda hood question. need quck answer
« Reply #1 on: July 09, 2010 - 03:28:13 PM »
Probably has something to do with the early hoods not having crumple zones.  The hood your looking at must have the crumple zones in the understructure.  The outward apearance would be the same though.
Offline Cuda Cody
  • Vancouver, WA
« Reply #2 on: July 09, 2010 - 03:30:51 PM »
Yes, 70's did not have the crumple zones.  I'm pretty sure they will all work though.
Offline GreenFish
« Reply #3 on: July 09, 2010 - 03:32:53 PM »
That's what I thought. Thanks guys!
Offline JayBee
« Reply #4 on: July 09, 2010 - 05:48:09 PM »
This may be late. '71 to '74 hoods had 3 holes drilled in the bottom left corner for the "Plymouth" nameplate, '70's didn't. They can be filled in though. Also, in Dutch's resto thread he mentions that the scoop's inserts mount from the back meaning it doesn't use the screws from the front.
John
1970 Barracuda convertible
2014 Toyota Avalon
Alaskan_TA
« Reply #5 on: July 14, 2010 - 10:45:23 PM »
1970 hoods used smaller diameter hinge bolts.
