Pull the Big wire that runs from the coil to the center of the distributor cap (pull from the cap, leave in the coil), position it close to ground (make sure there's no fuel leaks).. Have someone crank the car & see if a bright blue spark jumps... If not the problem is the coil or before, if it does the problem is with the distributor.
