Author Topic: gas gauge  (Read 2107 times)
Offline rt rag
  • 1970 Challenger RT 440 automatic
gas gauge
« on: July 10, 2010 - 01:19:35 PM »
Since restoring  my Challenger, the gas gauge won't work. It didn't work the first time I started the car and then briefly worked on a short drive. Now its not working. I grounded the blue wire from the sending unit, and I got a reading from the gauge, although it didn't read full as some members had indicated that it should. Is it the sending unit or is the sending unit not grounded properly.
Offline 72cudamaan
Re: gas gauge
« Reply #1 on: July 10, 2010 - 02:11:53 PM »
Sounds like a partial ground. Try running a wire from the blue sender wire directly to the neg post on the battery and see what happens.
If I cant fix it, it's broke
Andy  (phukker whither)
Re: gas gauge
« Reply #2 on: July 11, 2010 - 08:24:54 PM »
if you get no reading through the sender but the guage reads grounding the wires the sending unit is the problem
Offline rt rag
Re: gas gauge
« Reply #3 on: July 25, 2010 - 10:34:26 AM »
Replaced the sending unit yesterday and put a new ground strap on the fuel line and the gauge still won't work. I did ground the blue wire and I got a reading from the gauge. Not sure what to try now..
Re: gas gauge
« Reply #4 on: July 25, 2010 - 12:14:01 PM »
 :popcorn:  Just learning......
Re: gas gauge
« Reply #5 on: July 25, 2010 - 01:47:27 PM »
When you ground that blue wire on the sending unit, your gauge should not only go to full, but a bit past that. It sounds like that isn't the case for you. If your temp. gauge is fine, I suspect your fuel gauge isn't working correctly.
Offline rt rag
Re: gas gauge
« Reply #6 on: July 25, 2010 - 05:24:40 PM »
I ground the b lue wire to the battery and it did go over the full line. Maybe I have a bad ground?
Re: gas gauge
« Reply #7 on: July 25, 2010 - 07:32:48 PM »
How are the temp & oil pressure gauges doing?....If they are having problems you may have a voltage limiter or other power supply problem. If not them it's possible for the wiring that runs from the sending unit back to the fuel gauge has issues, maybe why grounding it did not put the gauge to full.
