Author Topic: Left side fresh air vent  (Read 714 times)
Offline SwissCuda
« on: July 11, 2010 - 10:41:26 AM »
Hallo,
I am looking for the EXACT measurements of the left side fresh air vent hole on the lower cowl panel.
I need Diameter/Distance from Firewall/ distance from the left panel
(A paper template to mask the correct holes would be fantastic!!!)
Reward to who can help me
Many Thanks!!
R.
Re: Left side fresh air vent
« Reply #1 on: July 11, 2010 - 12:58:03 PM »
This picture should get you very close to getting the exact measurements.
« Reply #2 on: July 11, 2010 - 01:09:51 PM »
Unless you have an original inner cowl vent housing, you'll need to likely fabricate one.
I used an HVAC stove hat. After it was welded in, I cut out the inner frame which enabled the flap to clear. Fit perfect. Hole was very close to original size requirement. Sandblast the edges prior to welding in since it's galvanized.
