Author Topic: painless harness  (Read 1708 times)
Offline black71
  • eph 6:12
painless harness
« on: July 12, 2010 - 01:24:21 AM »
Re: painless harness
« Reply #1 on: July 13, 2010 - 12:08:22 PM »
Should work for you but it is still a lot of hours to install
Offline black71
  • eph 6:12
« Reply #2 on: July 14, 2010 - 12:45:34 AM »
hmmm k......what do you think is my best bet? i'm wantin to hide all the wiring the best i can and in the future run power windows and a nice stereo system
Offline ShelbyDogg
« Reply #3 on: July 14, 2010 - 12:48:01 AM »
One thing about Painless Wiring. They don't have any Mopar ends on the end like GM wiring does.  They can't get the ends so you have to splice.  Ask them about this before you order.
Offline GoodysGotaCuda
« Reply #4 on: July 14, 2010 - 12:49:28 AM »
As long as you are capable of the actual wiring and making endless good/quality connections it is a great idea. As mentioned the connectors aren't the easiest to find for mopars. It takes quite a bit of time to install for sure, a little overwhelming initially
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline black71
  • eph 6:12
« Reply #5 on: July 14, 2010 - 01:15:24 AM »
i have my old wiring, its jus been hacked and some of it fried...could i make the connections work with painless kit?
Offline black71
  • eph 6:12
« Reply #6 on: July 14, 2010 - 01:19:19 AM »
theses thing also looked amazing..looks like they might actually be fun to install
http://www.isispower.com/products.html?ProductID=ISIS3BOXZ
Offline point45
« Reply #7 on: July 14, 2010 - 04:32:23 AM »
installed one in my barracuda a few months ago. Seemed like alot of work at first but i just started at the tail end and worked my way forward.
I used all of the original connectors from the old harness that i just ripped out. The colors on the ignition column didnt work out exactly but was easy enough to decode using a wiring diagram and multimeter.
Took about a solid weekends worth of time.
Offline Devil
  • Forward, Together Forward
    • Ryan's Cars in Barns
« Reply #8 on: July 14, 2010 - 03:04:04 PM »
Did the same with my 71 Challenger last year.  It was easy to do, just take off the old end, clean it and attach it to the new wire, and replace where needed.  Took me a few weekends, but I didn't have full days to work on the car.
Ryan
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
