Author Topic: idle solinoid  (Read 1258 times)
Offline 30below
idle solinoid
« on: July 12, 2010 - 09:02:53 AM »
Where does the wire hook up to?If im reading the wiring schematic correctly,it goes to the alt.,along with the dark blue wire.My new M andH wiring harness has no provision for it.73 Cuda,340
Offline Aussie Challenger
Re: idle solinoid
« Reply #1 on: July 12, 2010 - 09:26:08 AM »
Ignition power, 12v, not distributor side.   :bigsmile:
Re: idle solinoid
« Reply #2 on: July 12, 2010 - 09:54:04 AM »
My '73 340's solenoid plugged onto one of the alternator terminals , then the plug for the alt. plugged into the backside of that terminal (blue one I'm confident)...piggyback.
Offline 30below
Re: idle solinoid
« Reply #3 on: July 13, 2010 - 08:30:13 AM »
Thanks,guess i read it right.D o they make a special terminal to piggyback?
Re: idle solinoid
« Reply #4 on: July 13, 2010 - 09:25:48 AM »
Piggyback terminals are a common piece, but the molded insulator used was special, I've never seen one anywhere else.    Maybe a common part used on 70's Mopars.
« Last Edit: July 13, 2010 - 09:29:04 AM by Bullitt- »
Offline 30below
Re: idle solinoid
« Reply #5 on: July 14, 2010 - 08:55:41 AM »
Thanks,the pictures are great
