Author Topic: My new TCI tranny just blowed *pictures*  (Read 13410 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: My new TCI tranny just blowed
« Reply #15 on: July 13, 2010 - 12:11:09 PM »
Would ofcourse be great to try to rebuild a transmission via the web. :thumbsup:
What about the converter? Waste? Even if that one isn't the rootcause it will propably be full of metal that I can't get out?
Per
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline dutch
« Reply #16 on: July 13, 2010 - 01:15:29 PM »
awesome Terry !!  :bigshades: :2thumbs:
*** Bart ***
Offline tactransman
« Reply #17 on: July 13, 2010 - 01:19:17 PM »
What about the converter? Waste? Even if that one isn't the root cause it will probably be full of metal that I can't get out?
You can flush it if you put clean transmission fluid in it and dump it over a bucket a bunch of times. I think that it is going to be your problem spot though.
Terry-tactransman
Union, Mo.
« Reply #18 on: July 13, 2010 - 02:31:42 PM »
I really apreciate your effort here Terry but I don't dare to take the risc of using that converter if there is the slightest chance that it's garbage.
Looks like I will have some fun sanding the Challengerbody this summer instead
of burning some rubber. :(
Per
Offline UKcuda
  • Tell them I'm on my way
« Reply #19 on: July 13, 2010 - 04:15:06 PM »
Per
What a bummer, does this mean no nats trip, or do you have a spare converter as well as trans?
'72 'cuda
« Reply #20 on: July 13, 2010 - 04:56:51 PM »
No Steve, I don't have the old one. Used it for a GTX I had before and I don't think
I can get one overhere either.
For the Nats I don't know right now.
Per
Offline UKcuda
« Reply #21 on: July 14, 2010 - 02:36:31 AM »
I have a spare 727 converter, if I could get it to you in time ??
'72 'cuda
« Reply #22 on: July 14, 2010 - 03:43:02 AM »
Steve, is it a stock converter? I guess I need some more stall with my 500 stroker and 3.55 gears?
Terry, for my understanding, how come that the reverse works if the converter is broken? :clueless:
Per
Offline UKcuda
« Reply #23 on: July 14, 2010 - 05:44:16 AM »
Steve, is it a stock converter? I guess I need some more stall with my 500 stroker and 3.55 gears?.........
Well I have two spare ones actually.
Thay are both stock but are from SB 727s so I think will give you more stall on a BB motor.  If it can get you to the Nats then you are welcome to borrow either until you get your TCI stuff back together.
One of these is even the smaller SB one (10 and something inches) which I believe is good for even more stall on a larger motor.  It is neutral balance non lock-up.
The other one may be from a lock up transmission, I don't know how to tell without having seen the trans. that it came from.
Terry ??
'72 'cuda
Offline dutch
« Reply #24 on: July 14, 2010 - 06:33:09 AM »
Per, I`ve got one here from my BB727 you can borrow. It`s the one out of my cuda( 440-4.10.)   I`m not sure it`s in top shape since there was pretty much metallic in the trans oil when I got the car, but I drove it a few times with fresh oil and it seemed to be fine.
*** Bart ***
Offline tactransman
« Reply #25 on: July 14, 2010 - 08:58:28 AM »
A lock up converter will NEVER have a drain plug in between the converter bolt pads,so if they both have drain plugs they will work. Also ,a lock up will have 23 splines for the input and a Non lock up will be 24. (hard to count inside the converter though) .
Terry-tactransman
Union, Mo.
Offline UKcuda
« Reply #26 on: July 14, 2010 - 01:23:07 PM »
As I've said before, Terry you are a legend.
Anyway, it looks like Bart has a converter more local than mine.
While we are on the subject Terry, can you confirm if I'm right about a smaller converter on a larger engine will generally = more stall ?
I plan to use my 10 and a bit inch one behind my Magnum 360 (I know it needs to be weighted, I have got the right weight to add for the Magnum).
'72 'cuda
Offline tactransman
« Reply #27 on: July 14, 2010 - 01:25:38 PM »
Yes,the smaller the "bowl" the higher the stall.
Terry-tactransman
Union, Mo.
« Reply #28 on: July 14, 2010 - 03:25:32 PM »
I'm trying to be a very nice husband for the moment so I might get some money to spend. Although I'm extremly greatful for your offers on the converters I would feel somewhat better with a new one together with my new engine and rearend.
I'm almost ready to pull the tranny and it isn't anything I would like to do anytime soon again. :eek4:
Per
« Reply #29 on: July 15, 2010 - 03:18:16 PM »
The transmission is pulled, now just digging somewhere after some $$$. :smilielol:
Per
