Author Topic: How to make Wipers smooooth?  (Read 3706 times)
Offline 422STROKER
  • Member Since 6/3/06
« on: July 12, 2010 - 05:48:20 PM »
Well, after getting caught in a hellacious rain/hail/wind storm.  I need to know how to make the wipers smoothly glide across the window.  The mechanisms seem ok, a little clunky but the wipers seem grabby on the glass.  It gets old after 40 minutes.LOL
Anyone have any ideas?
Tom
Tom
Re: How to make Wipers smooooth?
« Reply #1 on: July 12, 2010 - 05:51:53 PM »
Even with wiper blades that are only a year old, and a fresh coat of Rain-X on my windshield, mine did the same thing.    :1zhelp:
Offline 422STROKER
« Reply #2 on: July 12, 2010 - 05:53:39 PM »
No rain x but the blades are a few years old.  the don't have too much use on them but do have some time with rain.  Frustrating to listen to all that racket.
Tom
I can feel it in the brake and gas pedal!
Tom
« Reply #3 on: July 12, 2010 - 05:58:37 PM »
I use the original style squeeze bottle of Rain-X & a piece of paper towel to apply, when I finish the glass I wipe off the blades with the damp paper towel...All kinds of black comes off at first but the old blades run smooth till they fall apart.
Offline 73EStroker
« Reply #4 on: July 12, 2010 - 11:01:37 PM »
I use brand new blades and rain-x. Just like a new car now. Soap cleaning of the blades every few weeks help too as you get the grit off.
Barry (Salmon Arm)
Offline 422STROKER
« Reply #5 on: July 12, 2010 - 11:03:10 PM »
Sounds like I need some Rain-x, it's raining pretty good now and I got a long drive coming up.
Tom
Tom
Offline dutch
« Reply #6 on: July 13, 2010 - 05:19:51 AM »
in my experience blades over a year old have to be replaced.  :2cents:
*** Bart ***
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #7 on: July 13, 2010 - 05:30:34 AM »
I agree with Rain-X on the windshield and thoroughly cleaning the rubber blades.  You will turn your cleaning rag black from the junk that's on the blades.  A soapy rag does the trick.  Replacing the blades every 6 months helps too.  They don't last as long as they used to.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
« Reply #8 on: July 13, 2010 - 08:06:27 AM »
The Blades on our '98 GT lasted 10+ years using the method I described above, now it was kept in the garage & only had 24K or so on it then but I doubt these hobby cars will see as much use/abuse.
Offline 72cudamaan
« Reply #9 on: July 13, 2010 - 08:34:00 AM »
Using some rubbing alcohol on the blades will work wonders. Cuts the road film off easily. :cheers:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 422STROKER
« Reply #10 on: July 13, 2010 - 06:06:49 PM »
Well, the Adam's detail spray worked good enough for the ride home.  says it's good on glass so i gave it a shot on the side of 83N.  Worked pretty good, the wipers rode smooth for a good while, it rained quite a bit on the way home too but went ok.
Thanks guys,  I figured it was the mechanism.
Tom
Although, is the wiper supposed to cross the cowl trim on every pass?  Mine does, I wonder if there is something up with the motor?
Tom
Offline 500Stroker
« Reply #11 on: July 13, 2010 - 06:18:31 PM »
You need the new style blades that will still fit on our arms.  Not all brands fit.  I forget the brand that I purchased but they glide across the windshield as smooth as silk.  I used to hate running the wipers but not no more.
The style looks like this:
Offline 500Stroker
Offline 422STROKER
« Reply #13 on: July 13, 2010 - 06:21:20 PM »
Thanks I'll have to check out a set, I like the stainless ones on the car now but they are useless in actual rain.LOL
Tom :clapping:
Tom
Offline 73EStroker
« Reply #14 on: July 14, 2010 - 11:01:17 PM »
I found new Trico Exact-Fit blades Cat# 16-2 that are listed for Challenger/Cudas 70-74. Those plastic pieces bind up on the underside of the hood. These Tricos are made of steel and look exactly like the originals
Barry (Salmon Arm)
