Author Topic: Bad Vendor Alert: XV Motorsports  (Read 13457 times)
Offline ajantics
    • Yeah......Im a drummer!
Re: Bad Vendor Alert: XV Motorsports
« Reply #30 on: August 02, 2010 - 05:01:13 PM »
Hey there MJS73, do you happen to have a link for the Bouchillon tank/pump? I have been looking all over the site and I can't find it ??? I would like to order one :thumbsup:
70 Barracuda
73 'Cuda
2003 Dodge Ram 3/4ton
2009 G37s
Offline MJS73
    • Mike's 1973 Challenger
« Reply #31 on: August 02, 2010 - 06:55:18 PM »
I can forward Bouchillon's email to you, if you email me at mike@mikes73.com, or call JR at Bouchillon.
« Last Edit: August 03, 2010 - 10:38:58 AM by MJS73 »
www.mikes73.com
Offline Choppintime
« Reply #32 on: August 03, 2010 - 06:46:51 PM »
Any pictures of the XV tank and also the Bouichillon tank? Love to see either or both at this point.
Offline 8657hemi
« Reply #33 on: August 03, 2010 - 08:15:05 PM »
I've purchased and installed one of their tanks with the internal pump. So far so good. It's only been about 400 miles though. Which connections are going bad? Internally? The connector on the top of the tank was shady and needed modifying to get to fit securely. Damn - a thousand dollars - I better not have a problem!
'86 D150 - '03 5.7 Hemi, 545RFE
'72 Charger - '08 5.7 Hemi, 904
'73 Barracuda - '08 5.7 Hemi, 727
'73 Challenger - '08 5.7 Hemi, 727
Offline 6PKRTSE
« Reply #34 on: August 04, 2010 - 02:36:34 PM »
I ordered one of their box tubing rad supports for an E-Body. It took several months to get it. Look pretty good from what I see but I still haven't installed it yet. The Challenger fab work has been put on the back burner for awhile until I get more money to move forward..
1970 Charger R/T S.E. 440 Six Pack
1970 CHALLENGER R/T, 25.5 Cert, 528 Alum 16 plug HEMI twin turbo.
1970 Charger 500 S.E. 440 4 BBL.
1970 Road Runner 383 4 BBL
1996 2500 RAM 488 V-10 4X4
2012 Challenger R/T Classic
Offline MJS73
« Reply #35 on: August 05, 2010 - 11:18:55 AM »
Yes, it's that external connection.  Very loose and wouldn't hold, even with bracing on it.  No pics (wish I'd thoht to take some) but if your pump shuts off while driving it's that connection.
www.mikes73.com
Offline 70_Hemi_Cuda
  • Mr. Cheese
« Reply #36 on: August 05, 2010 - 11:47:19 AM »
I like the looks of the XV stage 2 rear suspension but due to the modifications needed I'm probably going to go with the RMS Street Lynx rear kit.
1970 Plymouth Cuda 383 4-Speed Shaker
2001 Audi A6 4.2 V8
1992 Mitsubishi 3000GT VR4
Offline willhaven
« Reply #37 on: August 05, 2010 - 09:55:59 PM »
They both require welding right?
  • Mr. Cheese
« Reply #38 on: August 06, 2010 - 12:51:01 AM »
Yeah, its more or less I'd like to not have to worry about relocating or modifying my gas tank and messing around modifying every single bracket and piece in the XV kit to make it work because my springs have been relocated in 3 inches into the frame rails (MP kit). I know there was a guy on here that modified the kit because he had his springs mounts moved in and it seemed like a really big deal.
The RMS street lynx kit on the other hand would require much less fabrication and modification, the only welding is the top strut mount area and the kit works with the MP spring relocation kit so I dont have to try and figure out all new mounting spots myself.
2001 Audi A6 4.2 V8
Offline jvike
  • Pro-Touring Cuda
« Reply #39 on: August 06, 2010 - 11:02:36 AM »
I did like gkring and moved mine invards 1" with the Dr.Diff spring relocation kit. Panhard-bar clears the gastank when you use an 8-3/4. no problems.
  • Mr. Cheese
« Reply #40 on: August 06, 2010 - 11:47:30 AM »
Ah gotcha, it was just the S60 that had the issues with the gas tank then.
I think I'll still stick with the RMS kit just because its a little cheaper and it will be plenty good enough for my handling requirements
2001 Audi A6 4.2 V8
