Bad fitting rear valance
Author Topic: Bad fitting rear valance  (Read 18693 times)
Offline 73Chally
Re: Bad fitting rear valance
« Reply #45 on: July 17, 2010 - 05:33:29 PM »
The fit looks better, but it also looks kind of like your bumper is sticking out further than normal.  The gap between the bumper and the body looks wider than on some of the other pics posted here.
Offline tomsa
    • My cars in swedish
« Reply #46 on: July 17, 2010 - 05:34:14 PM »
You me page 5 I guess
Something like that but mine is also to wide so I had to cut it
   I know it can be frustrating but remember it fit at one time...
You might get some insight from post on page 3 of my resto thread
 http://www.cuda-challenger.com/cc/index.php?topic=31954.100
Offline tomsa
« Reply #47 on: July 17, 2010 - 05:36:18 PM »
Yes but there is no sign of mishaps in those brackets or on the body so that I don´t know anything about  :dunno:
Offline tomsa
« Reply #48 on: July 17, 2010 - 05:39:39 PM »
Looking at the pics purple1 provided it´s not the same valance as mine
The one on his pics are much "thicker"
And as 73chally wrote it looks like my bumper is sticking out further than normal
Under the green line on my pic is where the new quater panel is replaced
« Last Edit: July 17, 2010 - 06:43:27 PM by tomsa »
Offline quapman
    • Auto-Grip on Facebook
« Reply #49 on: July 17, 2010 - 05:55:58 PM »
I'd agree that the main issue is a low quality, poorly made quarter patch.
You might be able to loosen the bolts on the bumper guard and move it outward a little.
Offline tomsa
« Reply #50 on: July 17, 2010 - 06:45:57 PM »
You mean outward side ways?
Yes that´s possible but I find it more of a problem that the bumper guard is way to far out back wards
Offline quapman
« Reply #51 on: July 18, 2010 - 05:04:59 PM »
Sideways, yes.
Your bumper is probably fine and the patch panel is the problem again, with the bumper "pocket" in the wrong place.
Offline tomsa
« Reply #52 on: July 19, 2010 - 03:20:24 AM »
Sideways, yes.
No the bumper pocket are placed at the correct place
If you look at this pic (the left pic of those 2) the patch panel is replaced under that green line so the upper part of the pocket is the stock panel
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #53 on: July 19, 2010 - 08:11:30 AM »
Only diff. in the valance is mine has the exhaust cutouts. Angle of the pic maybe? I does look like the bumper is sticking out a bit more than it should. Has the car ever been hit in the rear? Could it be the whole area has been pushed around or something?
« Last Edit: July 19, 2010 - 08:17:45 AM by purple1 »
Worlds first e-body trailer.    Severna Park, Maryland
Offline tomsa
« Reply #54 on: July 19, 2010 - 08:18:31 AM »
Quote from: purple1
Only diff. in the valance is mine has the exhaust cutouts. Angle of the pic maybe? I does look like the bunper is sticking out a bit more than it should. Has the car ever been hit in the rear? Could it be the whole area has been pushed around or something?
Maybe an optical illusion then  :)
The car has been in Sweden since 1976 and not hit in the rear in that time anyway
If someone repaired it before that they have done a great job because I can´t see anything looking like that
Same colour,no welding in the frame etc etc
Offline purple1
« Reply #55 on: July 19, 2010 - 08:24:20 AM »
Then the only thing that changed was the repair patch. Sounds like we have covered most other possibilities. Sorry to say that has to be it.
Offline tomsa
« Reply #56 on: July 19, 2010 - 08:28:32 AM »
I guess that´s the only solution but it can´t have moved the bumper pocket because only halv of ut has been replaced and that fitted perfect and also the part at the wheel area so the lengt beetween the was correct
So I make the valance to fit on the car or will make a new in fiber glass
Havn´t decided yet
Offline swede-cuda
« Reply #57 on: July 23, 2010 - 03:20:43 PM »
 :wave:if it where my car i would rip my hair :horse:and then investigate further to find out whats wrong,and fix it.depending on what you are going with this car,maybe remake the valance.fiberglass valance sounds like a hassle.if the car is a keeper,do it right while you have it in pieces. :pullinghair:
Offline dutch
« Reply #58 on: July 23, 2010 - 03:45:10 PM »
I`d cut the bumperbrackets and weld them where you want the bumper to seat and go from there.  In the end you want to have straight gaps and if you have to cut the valance 20x to get it right ,so be it,  but if your bumper sits crooked in there, it will never look straight.   :2cents:
*** Bart ***
Offline tomsa
« Reply #59 on: July 23, 2010 - 04:06:26 PM »
But the real problem is that the valance is to long and doesn´t fit at all
The quater patch panels are changed but the upper hole for the valance IS NOT moved and that is also in the wrong place
If I shall fix that I have to move the whole rear fenders out to get a wider body but the the bumper will have to get wider also
So I make a new valance in fiber glass that fits on my car
