Author Topic: Electric fan question  (Read 1010 times)
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
« on: July 14, 2010 - 02:43:01 PM »
Is anyone here running an electric fan on their car?  What I would like to know is how it is wired up and how it is turned on?  If it is thermostatically controlled, do you use a radiator probe or a sensor in the intake manifold?
{oo/===\oo}
Offline 6packCuda
Re: Electric fan question
« Reply #1 on: July 14, 2010 - 04:12:51 PM »
The thermostatically controlled ones use a sensor in the intake. Or you can just hook it up with a toggle switch.
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #2 on: July 14, 2010 - 05:35:46 PM »
I have a set of fans in my Cuda that are thermostatically controlled with a fan thermostat in the intake.  There is also a relay for each fan with the main power directly from the battery and the relay switch power to switched 12v power source.
I also recently installed an electric fan in my '92 Toyota truck.   The fan has been hooked up to work both thermostatically with a probe in the radiator fins and able to be overridden with a manual switch.  The probe works in conjunction with a controller that you can adjust the trigger temperature with a dial.  On the Cuda, I would have to change the fan thermostat with a different one to adjust the temperature it activates at.  The manual switch just bypasses the controller.
If you have A/C and a two speed set up for your fan/s or two fan, there can be a provision to hook a wire to your compressor wire to force activate the second fan or high speed when the A/C is on, just like the manual switch would.
Personally I like having the temp probe in the intake.  It is clean and simple.
« Reply #3 on: July 14, 2010 - 07:35:23 PM »
I used a 2006 Chevy HHR fan.( $50 rock auto ) I welded a bung onto the rad for the thermoswitch. I used a painless wiring kit ( with a relay)to wire it up. Works like a champ! Sucks a shop rag to the rad and holds it there so I know it moves air!
Offline BB73Challenger
« Reply #4 on: July 14, 2010 - 08:23:36 PM »
I'm running dual pulling fans controlled with an adjustable temp. probe in the radiator in my big block Chally.
My problem was never moving enough air ( hot at idle/traffic, cool on the freeway ) and that cured it all.
Jeff from Cleveland, Ohio
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #5 on: July 15, 2010 - 08:19:28 AM »
From what I can tell this is one of the best kept secrets in the hoby!  Based on feedback I have read on this site and others.
Don
Member Since January 14, 2002
