Author Topic: Correct me if I'm wrong...  (Read 837 times)
Offline Marty73
  • '73 Challenger
« on: July 15, 2010 - 08:00:01 PM »
Correct me if I'm wrong, but the last year Mopar produced the LA block was in 2002 right?
On that note - if I go post 2002 (I assume magnum block) what flywheel would i need and will it mount to my 73 Chally 727 tranny?
Thanks! You guys are the best!
Comin' at ya like a herd of turtles
Re: Correct me if I'm wrong...
« Reply #1 on: July 16, 2010 - 03:30:11 AM »
after 2002 all they had was the 4.7 & 5.7 Hemi , pre 2002 would be magnum back to back to 93 , any of the magnums will bolt up , not sure on the 5.7 to the LA belhousing
Offline Marty73
  • '73 Challenger
« Reply #2 on: July 16, 2010 - 12:15:13 PM »
Thanks!
Offline Wollfen
  • The Beast!! 1970 RT Challenger 383 4spd
« Reply #3 on: July 16, 2010 - 12:42:51 PM »
727 Trannies would use a flex plate not a flywheel, flywheels are for manuals, well, they are in Australia? :burnout: :aussie:
1970 Dodge Challenger RT 383 4SPD
« Reply #4 on: July 16, 2010 - 12:44:17 PM »
Did the Sprinter ever have a 5.2 in it?  I thought I remembered reading some dealer info on them years ago.  I thought they continued the 5.2 for another year or two and only put them in the Sprinters.  Maybe that was planned but never accually happened.
Offline heminut
« Reply #5 on: July 16, 2010 - 01:27:11 PM »
The 5.7 and 6.1 Hemis will bolt right up to the LA bellhousing. There is no need whatsoever for the 'adapter' that Bouchillon sells!
1970 5.7 Hemi Cuda
Offline Cooter
    • christinecarclub.com
« Reply #6 on: July 17, 2010 - 10:43:00 PM »
If running a manual trans, the Magnum engines are a different balance than the '71?-?? 360 enignes...In other words, running a 1974 360 flywheel on a 1997 360 Magnum will not work...Can run the stock Magnum flywheel with the stock Magnum engine as long as everything else bolts up, IE: Clutch etc..
Offline shadango
« Reply #7 on: July 19, 2010 - 01:43:14 PM »
I have an 03' Durango with the 5.9....was under the impression 2003 was the last year for the LA blocks.
 :dunno:
Also, the first year for the Magnum 318 was 92 (and the best year to have from what I was told)......I have one in my 92 Dakota. (LOVE that little truck!)
