Author Topic: valve cover oil breather  (Read 3840 times)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« on: July 16, 2010 - 04:37:27 AM »
I have an after market air cleaner on the carb.  I know that this thing connects to the OEM air cleaner, but I don't want it hooked up to the new one.  What is the exact purpose of this.  Does it need to breathe or can it be plugged?  I have cheese cloth on the end of it to keep out any dust.
340 engine---passenger side valve cover
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline UKcuda
  • Tell them I'm on my way
Re: valve cover oil breather
« Reply #1 on: July 16, 2010 - 05:06:03 AM »
Its where the air gets sucked in at the far end of the PCV system.  It needs to be open but I believe the only reason to connect to the air cleaner is so that it receives filtered air (poss. also for some emmission reason, like fumes that might escape from it).
You could just put some sort of filter over it (I note what you say about the cloth) or get one which is just a filter itself, I think some of the older cars just had it like that from factory.
'72 'cuda
Offline Supercuda
« Reply #2 on: July 16, 2010 - 09:18:04 AM »
This style has a baffle to keep oil in the engine, but no filtration medium, so it should be plumbed to the clea side of the air cleaner. Many aftermarket air cleaners have a nipple that can be installed for this. My personal choice is to not molest the new air cleaner base, and install a breather with filter in it, that will fit in the original location. Second option is to pack filter material into the breather can you have, and run it that way.
« Reply #3 on: July 16, 2010 - 09:30:43 AM »
It should be simple enough to find a breather without the tube... Check the measurement of where it pushes in...... Most of the local parts stores carry some in their dress-up dept.
http://www.summitracing.com/search/Part-Type/Valve-Cover-Breathers/Valve-Cover-Breather-Attachment/Push-in/Breather-Tube/No/?keyword=breather&Ns=Price|Asc
Offline Aussie Challenger
« Reply #4 on: July 16, 2010 - 09:52:09 AM »
It is supposed to have filtered air to go into the engine to replace the air sucked out through the PCV valve for normal driving, however under hard acceleration there is a build up of pressure inside the engine and it then blows out into the air cleaner. If you fit a breather can on the rocker cover as some do you run the risk of oil fumes running over your nice clean engine.   :bigsmile:
Offline Kevin71
« Reply #5 on: July 16, 2010 - 10:39:20 AM »
If this attached to the filter in any way wouldn't the vacum caused by the running engine put a negative pressure on the air flow pulling it out of the crank and back into the engine like the PCV.  It would have to have more negative pressure than the engine does to suck air out of the air cleaner.  I have always wondered how this works.  It doesn't make sense to me.  Mine is attached to the bottom of a aftermarket air cleaner.  If oil fumes come out of it then it is blowing out and recircluating back thru the carb makes sense.  How is the air being sucked out of the crank case replaced with air coming in.  I am guessing thru the carb.
« Reply #6 on: July 16, 2010 - 11:01:12 AM »
You answered the question, the air is sucked out of the engine (crankcase) through the PCV, excess blowby is pushed up the air tube and into the air stream into the carby and burnt.   :2thumbs:
Offline Aracer
« Reply #7 on: July 18, 2010 - 12:48:58 AM »
When you rev it, pressure forces the blow by from the pistons out as smoke. At idle most is sucked up the PVC. Old cars had a tube down the back of the engine for cross draft ventilation.
Offline mcgheejt
« Reply #8 on: July 18, 2010 - 06:57:09 AM »
If you decide to go with an aftermarket, let me know.  I have been looking for one of those  :bigsmile:.
Offline hooD
  • detroit iron
« Reply #9 on: July 21, 2010 - 04:33:06 AM »
I picked this up at autozone yesterday for $9.99 and it's a perfect fit!
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline mcgheejt
« Reply #10 on: July 21, 2010 - 08:50:43 AM »
 :lol:  What I should have said is, I have been looking for an original and if you purchased an aftermarket, would you be interested in selling your old one?   :bigsmile:
Offline Supercuda
« Reply #11 on: July 21, 2010 - 10:32:55 AM »
Don't forget to ask for the ribbed hose that's attached to it.
Offline hooD
  • detroit iron
« Reply #12 on: July 22, 2010 - 04:42:37 AM »
Sorry, but I am going to keep the original breather.
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline CUDA JAS
  • vroooooom!
« Reply #13 on: July 22, 2010 - 03:16:20 PM »
Nice, I have some Mopar breather that i am puting on mine, eventually.
NOW, about that fuel fiilter!!!!
74 'cuda 360/727
Just call me a gearhead!
