Author Topic: Looking for a welder  (Read 3027 times)
Offline 06Daytona
« on: July 16, 2010 - 07:23:12 AM »
After I get the Challenger as a daily driver I'm planning on pulling the Cuda apart and redoing it properly. I'm looking for some recommendations for a new welder since I haven't done any for about 15 years and very little of that was on body panels. I've been asking around here to see what people are using, and that seems to be everything from 30 year old buzz boxes to brand new Mig/Tig rigs. I'll probably end up doing patchwork, some floorpan work maybe a quarter replacement or 2 and by the looks of it some boxing in on the uni body
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline the_engineers
Re: Looking for a welder
« Reply #1 on: July 16, 2010 - 07:34:13 AM »
Oh boy...this'll get more responses than Cudas vs Challengers.  My opinion is to get a 110 MIG machine from Lincoln or Miller, depending on budget. They seem to be easier to fine tune on lighter welds than a 220 machine.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline 72cudamaan
« Reply #2 on: July 16, 2010 - 08:28:35 AM »
A 110 unit will be plenty big enuf. DO get a brand name, they are definitely worth the little bit extra, and DO get a unit with gas. Flux  core isn't as user friendly and dirty.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #3 on: July 16, 2010 - 08:34:48 AM »
 :iagree:  I have a 110V Lincoln, had it for 15 plus years and it's done a ton of welding and never once caused me any trouble! As was said above DO get the gas kit! The flux core stuff makes a mess!
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #4 on: July 16, 2010 - 08:41:24 AM »
 :iagree: When it came time to weld the quarters on my trailer, we put the 220v mig up and got out a little 110v mig. Just make sure you get one with the gas hook up.  :2cents:
Worlds first e-body trailer.    Severna Park, Maryland
Offline ksierens
    • 70 Challenger Resurrection
« Reply #5 on: July 16, 2010 - 10:50:25 AM »
 :iagree: I have a 110v 120amp Lincoln (with gas) and it works great! I would also use Twenty Gage brand wire.
Kurt - SE Michigan
Offline heminut
« Reply #6 on: July 16, 2010 - 01:01:27 PM »
Definitely go with a 110 MIG with gas and the .023 wire. If you can stick weld then MIG is a piece of cake! I have a Lincoln 110 v. MIG that I used for all the sheetmetal work on my Cuda and it worked great!
1970 5.7 Hemi Cuda
Offline 06Daytona
« Reply #7 on: July 16, 2010 - 06:30:25 PM »
Thanks for all the help. I'm going to start looking at Lincolns around here this weekend since the only show is beyond the distance comfort zone for the Cuda.
Do you need a welding ticket to get AC 75? I heard from a welder that I used to work with that you needed one for all welding gases, but that was 15 years ago
Offline ntstlgl1970
  • T a c o c a t
« Reply #8 on: July 16, 2010 - 06:44:57 PM »
Heminut mentioned the most important thing - using .023" wire. I think you will be fine with a 110v setup with gas.
Offline 72cudamaan
« Reply #9 on: July 16, 2010 - 10:11:15 PM »
I actually have used .030 wire with better results. Use the same amperage and a little slower feed rate and I don't have burn through as much. But whatever works best for you. :2cents:
Offline Challenger III
« Reply #10 on: July 17, 2010 - 09:33:43 AM »
I am using a Hobart 110 also with .030 and 75/25 gas. Works great! Make sure you don't settle for the little bottle. Get the larger bottle and save numerous trips to the welding supply store!
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline elitecustombody
  • Supra collector
« Reply #11 on: July 17, 2010 - 09:45:14 AM »
I'd look into getting a Miller MIG welder, I have Miller 130 XP and  Lincoln Pro-MIG 135 as a back-up and can't stand the cheesy plastic wire feed drive Lincoln came up with, if you buy Lincoln,make sure it has upgraded wire feed system,
Stefan B
Offline 06Daytona
« Reply #12 on: July 17, 2010 - 09:58:22 AM »
I know the wire feed on the Lincoln I was using was garbage too. Aluminum wire kept binding and snagging on it. I'm going to take my time looking and I'm going to see if I can test fire before I buy too. I'm not sure what flavors of welders I can get in Puerto Rico, so I might be limited with what I can get here unless I get one special ordered. My wife is on cleaning rampage today, so I might take off and start looking soon.
Offline 72cudamaan
« Reply #13 on: July 17, 2010 - 07:18:57 PM »
Ya, you gotta use a spool gun to feed aluminum wire. :wave:
Offline lemming303
  • San Antonio, TX
« Reply #14 on: July 18, 2010 - 01:53:34 PM »
I asked this same question about a year ago and got a totally different answer! LOL
I was told to get the 220 because you can do so much more with it. Only a couple of people told me to get the 110! I still haven't bought one yet, but I think when I finally have the money and something doesn't come up that I will get one! It always seems that when I get some extra to use on the car something else comes up and I wind up using it to buy or fix something else. Oh well, that's life I guess!
Kevin
73 Challenger Rallye - first project
