News:
As usual after talking to countless frame shops they have either put me off or lack the desire to take on straightening the frame. So as always I have to engineer something on my own. I have removed all the suspension and leveled the car on jack stands 30" in the air. I constructed a rack I can level (the floor is out of level) and will drop markings down from the frame to the rack to take elevations and pull diagonals to get a basis by which I can pull the frame back into square if needed. I know the right front frame member is up by at least a 5/8". I have a beam 16' long constructed from three 2x12's and welded together a cradle I can attach to the frame that holds a hydraulic jack. I have points along the frame I can either drill a hole to attach to or use an existing one to utilize the cradle.
as I understand it these cars were assembled in as little as 58 minutes
5/8" does not sound that much, considering the way theese cars were put together. Is there any specs on how much the measurements could actually be off?
My front frame ends are different by 3/8" with respect to the floor. I consider that fine. Don't have any idea what factory tolerances are but 5/8" was probably 'good enough'?
