heater core
Author Topic: heater core  (Read 773 times)
Offline rwdeitrick
heater core
« on: July 17, 2010 - 06:15:05 PM »
has any one replaced a heater core in a 73 cuda ? I replaced all new hoses and now i got antifreeze driping in side the car on the passenger side.I was tould it was not hard but im not sure on what i need to take off,to get to the heater core.and is there a difference in quality on the heater cores i found some online with different prices  thanks Rod
Offline 422STROKER
  • Member Since 6/3/06
Re: heater core
« Reply #1 on: July 17, 2010 - 06:34:50 PM »
A/C or no A/C?
If no A/C it's easy, disconnect the cables, wires and 3 nuts in the engine bay along with one inside to the cowl vent if it's still there.  Oh and the heater hoses too.LOL
Tom
Tom
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: heater core
« Reply #2 on: July 17, 2010 - 06:47:05 PM »
just did it on my ac car but Alaskant/a posted the factory service manual if it.
 http://www.cuda-challenger.com/cc/index.php?topic=69799.msg714493#msg714493
Go Fast & Have Fun...
Re: heater core
« Reply #3 on: July 17, 2010 - 06:56:18 PM »
One other tip I can give you..The case is held together by several spring clips, the best way to remove/install that I have found is to insert a wide flat blade screwdriver in the bend at one end. Then you can easily open the clip back & it slips off/on.  Picked up my heater core from Oreily's, fit just fine
 Good time to restore the insides as well
http://www.rosevillemoparts.com/product_info.php/p/heater-box-seal-kit-non-ac-1970-74-e-body/products_id/2646
« Last Edit: July 17, 2010 - 06:57:53 PM by Bullitt- »
