Author Topic: Jeep/transmission techs - trans starting to slip?  (Read 1769 times)
Offline torredcuda
  • Epping NH joined 11/23/03
« on: July 18, 2010 - 03:20:54 PM »
A co-worker has an `03 Liberty,3.7 and recently the trans is starting to slip a bit.I drove it and it is fine when you take off slow but try and punch it and is slips/shudders a bit.Also if you don`t come to a complete stop it takes a second to go into gear.Any chance it doesn`t need a coplete rebiuld?I had it scanned and no codes but it said it`s running hot and fluid smells a touch burnt.Is there any other diagnosis the dealer or trans shop can do before going for a rebiuld?
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline 4 speed fish
Re: Jeep/transmission techs - trans starting to slip?
« Reply #1 on: July 18, 2010 - 04:09:04 PM »
Get the fluid changed first,then go from there.
« Reply #2 on: July 18, 2010 - 04:17:57 PM »
Funky smelling fluid isn't a good sign.  Trust me.    :pullinghair:
Offline torredcuda
« Reply #3 on: July 18, 2010 - 05:28:12 PM »
She said the fluid was changed last year by a shop and I`m wondering if they used the correct type?I`ll probably change the fluid and filter to see if it helps but ya Mike-burnt fluid is never good!
Jeff
Offline tactransman
« Reply #4 on: July 19, 2010 - 07:51:24 AM »
You need to check the CVI (clutch volume index) readings with a scan tool. That will tell what the condition of the clutch packs is.
« Last Edit: July 19, 2010 - 07:53:05 AM by tactransman »
Terry-tactransman
Union, Mo.
Offline torredcuda
« Reply #5 on: July 19, 2010 - 09:07:35 AM »
A local mechanic put his Snap On scanner on it and came up with no codes.Will the Snap On one work or should I have dealer or trans shop do it?
Jeff
Offline tactransman
« Reply #6 on: July 19, 2010 - 09:19:39 AM »
Yes,the Snap On scanner will work. You need to find out not just codes,but CVI numbers.
What is the mileage?
What does the pan look like?
42RLE
45RFE
Terry-tactransman
Union, Mo.
« Reply #7 on: July 19, 2010 - 10:03:51 AM »
I've had similar experiences with several Chrysler products that turned out to be the wrong fluid although burnt smell was not part of the symptoms... Two times adding a friction modifier solved the problem, on the other the fluid was changed to Mopar Spec fluid.
Offline torredcuda
« Reply #8 on: July 20, 2010 - 09:01:55 AM »
Checked the pan and it`s the 42RLE.
Jeff
Offline tactransman
« Reply #9 on: July 20, 2010 - 09:33:11 AM »
Have them get CVI numbers and post them.
Terry-tactransman
Union, Mo.
