Author Topic: Starting Problem  (Read 849 times)
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
Starting Problem
« on: July 18, 2010 - 10:11:29 PM »
When I turn the key, I get a loud knock: metal on metal.  Then the starter struggles to turn the engine over.  It is a mini starter on a 360ci.  I've never experienced this before.
 :feedback:
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
Re: Starting Problem
« Reply #1 on: July 18, 2010 - 10:15:42 PM »
See if the starter is loose, and also see if the converter flex plate bolts are tight. If one backed out It will make you think you spun a bearing
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #2 on: July 18, 2010 - 10:24:08 PM »
i would check the starter,,sounds like it is the problem,,that knock your talking about,is it just turn the key on ? not cranking?,,see if you can tell its the starter making the noise,,it shouldn't make a noise just turning the key to the start position
72rtchallenger
what happens in the garage
stays in the garage
« Reply #3 on: July 18, 2010 - 10:51:37 PM »
is the battery low on power or poor conections + or ground
Offline JoltinJoe
« Reply #4 on: July 20, 2010 - 07:58:12 PM »
Went to check the battery and checked the plug/distributor wires.  Find three loose distributor wire.   :screwy:Starts just fine again.  Thanks guys!
