Author Topic: Hot steering column  (Read 2792 times)
Offline shadango
Hot steering column
« on: July 19, 2010 - 01:25:45 PM »
After a hour long drive yesterday, 90 degree temps, I felt the key area of my steering column and it was HOT all the way around.
Felt on down to thefloor and still very hot.
Felt the steering shaft itself under the hood and it was very hot....so I assume what is happening is that the heat is traveling up the shaft and heating everything?
Is this common?  I have Dougs headers....they arent THAT close to the steering shaft....in the vicinity though.   :clueless:
Re: Hot steering column
« Reply #1 on: July 19, 2010 - 05:46:26 PM »
Yer 'Cuda's just    SOOOO      HOT
Offline shadango
« Reply #2 on: July 19, 2010 - 06:15:14 PM »
LOL
Ok, so does that mean "no big deal"  ?   :bigsmile:
No wonder its so damn hot in the car.....LOL
« Reply #3 on: July 19, 2010 - 06:25:32 PM »
I'm guessing your right on as to the source, these cars have more metal in them which transfers heat better than the plastic in today's cars.  Can't say I've ever noticed the column heat but I never ran headers in the past.....
  Just something to think about, the exhaust will be extra hot if your running lean or the timing is to advanced.  Otherwise contemplate a heat shield but yea with no A/C, black interior they are hot boxes.
Offline IMNCARN82
  • LeDZeP
« Reply #4 on: July 19, 2010 - 06:30:15 PM »
Yeah,They can get hot. I ended up with a whole roll of this foil/bubble wrap insulation from a job.Not sure what it's called. Used it under the carpet and saw a big decrease in temp. I'd even consider two layers. Use the foil tape. Right up behind the rear seat. Up under the dash.The stuff is real cheap at HomeDepot er somewhere like that.It looks just like the expensive stuff.But you tape it down. Lemme' get some pics... R/T
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #5 on: July 19, 2010 - 07:55:49 PM »
Headers that are close to the steering shaft will heat up the column, but as a norm, the exhaust manifolds dont really have that problem.  Or as bad a problem. Also remember that your brake portioning valve isnt that far away either.  If you are using headers, then consider a shield
Offline 422STROKER
  • Member Since 6/3/06
« Reply #6 on: July 19, 2010 - 08:39:57 PM »
I have the Dougs headers, but never noticed any heat from the column. Do you have a ignition key light?  Maybe it's stuck on?  Little green light in the column by the lock cylinder?  Just a thought.  Though it wont heat the whole column...LOL
I have the shield on the master too.
Tom
Tom
Offline shadango
« Reply #7 on: July 19, 2010 - 09:31:18 PM »
I'm liking that shield...where did ya get it?
I dont have the light hooked up in my coumn......first I thought "oh hell, an electrical problem"...but it was the same temp all up and down the column, to the floor....then felt the shft under the hood, and it was a little warmer even.
Makes sense I guess.
So what kinds of shields are available?
Offline 422STROKER
« Reply #8 on: July 20, 2010 - 05:47:02 AM »
I got it from Mancinis I think, there are polished and unpolished, maybe 15 bucks IIRC?
Tom :2thumbs:
Tom
Offline shadango
« Reply #9 on: July 20, 2010 - 06:31:46 AM »
Thanks.....found it on Mancini's....a little pricier than I hoped at $30
Does it seem to work?  Can you tell a difference at all in braking?
Offline drewcrane
« Reply #10 on: July 20, 2010 - 08:14:41 AM »
There is also this new product looks pretty cool
Offline 422STROKER
« Reply #11 on: July 20, 2010 - 07:06:39 PM »
I have manual discs and it seems to stop ok for me, I had a few panic stops on the way to Carlisle this year and it was hot out and now problems.
Tom
Price must have gone up!
Tom
Offline 500Stroker
« Reply #12 on: July 20, 2010 - 09:19:31 PM »
My column is very hot as well.  Has been since I noticed it a few years ago.  Figured it was heat coming in from the headers on the shaft since the entire passenger compartment is fatmated.  My column also has a 1" hole on the side of it.  When on the road driving you can feel the hot air coming in from the outside.
Offline shadango
« Reply #13 on: July 21, 2010 - 09:00:49 AM »
Tom
I have manual disks too, and was wondering if the heat could be cauisng a slight pull right I am having.  had the same damn pull with the drum brakes......oddly.  New brakes hoses, new calipers, rotors, rear cylinders, aluminum master cylinder......the only thing left would be either something in the suspension bent (front suspension all gonethru over this past winter...new bushings, tierod ends, BJ,s, t-bars, strut bars....
