Author Topic: Indicator on when braking??  (Read 997 times)
Offline punisher72
  • 70Challenger 440 4 speed yeeehaaaaa!!!!!!!
« on: July 19, 2010 - 08:55:35 PM »
Hey guys. My passenger front indicator comes on and stays on when I apply the brake? Can anybody shed some light on this? :clueless: thanx
Re: Indicator on when braking??
« Reply #1 on: July 19, 2010 - 09:23:06 PM »
One thing that can happen is one of the filaments in the bulb is broken & welded itself to the other filament sending power back through the system.    Possibly a bad switch in the column but I'd check the bulb thing 1st, cheep & easy.
« Reply #2 on: July 20, 2010 - 12:44:08 AM »
bad ground in the socket so it is finding another ground
Offline punisher72
« Reply #3 on: July 20, 2010 - 05:38:35 AM »
Thankyou,i will try the bulb and earth and see how it gos.  :cheers:
Offline ShelbyDogg
« Reply #4 on: July 21, 2010 - 02:04:43 PM »
Do you mean the Brake light indicator on the dash, right? If so, it means that your proportioning valve is too close to one side and has to be recentered. Tell us if this is the light that you mean.
Offline punisher72
« Reply #5 on: July 22, 2010 - 05:55:30 PM »
The indicator light above my speedo comes on as well as the indicator front right. The brake light on the dash dosent come on at all until the hand brake is applied. I haven't had a chance to check out the earthing fix yet. Will try today as I've got a day off and mopar Sunday is 2 sleeps away  :droolingbounce: :burnout:
