Author Topic: to rebuild or not to rebuild...  (Read 619 times)
Offline CUDA JAS
  • vroooooom!
« on: July 19, 2010 - 11:13:11 PM »
that is the question.
My 727 works fine.  Stong shifts at full throtle, no noticible slippage in any gear or shifts, but it leaks from what appears to be several spots.  Not sure where exactly.
The trans is from a 1980 NY, and does not appear to have ever been apart, or had the fluid or filter changed.  I do not think the trans needs to be rebuilt...but maybe it does.  I need to change the torq converter eventually, but not sure when that will happen, so it will have to come out eventually.
Is it possible to replace all of the seals that may be leaking without removing the trans from the car?
What should i look for?
Jas
« Last Edit: July 19, 2010 - 11:19:46 PM by CUDA JAS »
74 'cuda 360/727
Just call me a gearhead!
Offline 71chally416
    • The Streetwalker
Re: to rebuild or not to rebuild...
« Reply #1 on: July 19, 2010 - 11:38:15 PM »
The most likely suspects are the dipstick tube, the coolant lines and the pan. They can all be fixed with the tranny in place. If your front pump seal is leaking you obviously have to remove the tranny to get to it. Clean it off real good and find where it's leaking.
Offline don340-4
« Reply #2 on: July 19, 2010 - 11:52:26 PM »
 Shifter shaft seal most likely leaking too!  :wavingflag:
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
