Author Topic: Whinning noise in rear  (Read 1547 times)
Offline mjb765
« on: July 20, 2010 - 07:32:50 PM »
I have a whinning noise in the rear only under load. In neutral or coasting in gear the noise goes away. 8 3/4 rear......Sound like something set wrong in the chunk?? Backlash?? I'm thinking a bearing would make noise all the time?? Axle end play is good.
Re: Whinning noise in rear
« Reply #1 on: July 20, 2010 - 08:06:26 PM »
Is this something different than before?  Rear Wheel drive vehicles tend to have a "whine" under load. I was discussing the noise our Lincoln Navigator made with a mechanic & he said I was just not used to having the rear so near the passenger compartment.
Offline mjb765
« Reply #2 on: July 20, 2010 - 09:59:15 PM »
I put a used center section in and now have the noise. Wondering if it might be a backlash issue???  No vibration or anytthing else, just the whine under load.
Offline mojavered
  • Someday!
« Reply #3 on: July 20, 2010 - 11:30:50 PM »
If it was a backlash issue, wouldn't you have a clunk upon take off?  Or would that be something else?
Jason
Offline ntstlgl1970
  • T a c o c a t
« Reply #4 on: July 21, 2010 - 02:20:02 AM »
Rear pinion bearing. Is this a 489 or 742 case? If it's a 489, the crush sleeve may have gone away which will take out the bearings. Same deal with the navigator.
Offline mjb765
« Reply #5 on: July 21, 2010 - 09:48:06 AM »
It's a 489 case.  The whine is not too bad, but I hear it. Can I still drive it while I have my other center rebuilt?
Offline Supercuda
« Reply #6 on: July 21, 2010 - 10:49:32 AM »
Yes, but don't hammer on it while driving. That would be pulling the pin on this grenade. I like the "normal function" comment about the Lincoln. I don't think I want that guy working on any cars for me.
« Reply #7 on: July 21, 2010 - 11:33:49 AM »
   It made the same noise from new-65K when we sold it...was not that loud but you could tell a difference when on/off the gas.
Offline mjb765
« Reply #8 on: July 21, 2010 - 11:57:16 AM »
Good...thanks...
and far as normal noises go--I had a backlash clunk on a brand new truck I bought almost 20 years ago and several dealers and the factory said it was "normal"....not a happy noise, but I put 125,000 on the truck and never had any problems. Factory and dealer normal is sometimes different than what we would like.
