Ok, we're undertaking this mammoth task on my 1970 big block
Thanks for chronicaling it. I hope to do the same.
I did have a question:
You mentioned the drivetrain being too high, due to the positioning of the heaterbox and you talk about using different engine mounts? Is that right?
Was a different mount used or the rubber isolator?
I phoned Schmacher in Washington and he said that the isolators used for both the small block and big block are the same. Is this true?
But in the picture you clearly show a slimmer isolator.
Was a different isolator used or different engine mounts?
Your help would be most appreciated
Cheers
